    Bookmark multi words from multi lines in a text
    27 Posts 5 Posters 6.5k Views
      Alan Kilborn @guy038
      @guy038
      Haha, well, I was trying to keep it simple, according to the OP’s desire.
      But I will see what I can do.
        @guy038
        Sorry it took me so long, but here’s the revised script (it is actually shorter, now!) with your desired changes, plus as a bonus it also bookmarks lines:
        # -*- coding: utf-8 -*-
        from Npp import editor, editor1, editor2, notepad
        class T19249a(object):
            def __init__(self):
                SCE_UNIVERSAL_FOUND_STYLE = 31  # redmarking indicator number; name from N++ source code
                MARK_BOOKMARK = 24              # bookmarking marker number; name from N++ source code
                files_in_view_count_list = [ 0, 0 ]
                for (_, _, _, view) in notepad.getFiles(): files_in_view_count_list[view] += 1
                if files_in_view_count_list[0] == 0 or files_in_view_count_list[1] == 0:
                    notepad.messageBox('This script requires 2 views to be open', '')
                    return
                search_term_list = editor2.getText().splitlines()  # search terms are in secondary view
                for search_term in search_term_list:
                    matches = []
                    editor1.research(search_term, lambda m: matches.append(m.span(0)))
                    editor1.setIndicatorCurrent(SCE_UNIVERSAL_FOUND_STYLE)
                    for m in matches:
                        editor1.indicatorFillRange(m[0], m[1] - m[0])
                        editor1.markerAdd(editor1.lineFromPosition(m[0]), MARK_BOOKMARK)
        if __name__ == '__main__': T19249a()
        For instance we would be able to get whole words only
        I think you can use the \b assertion in your regexes for this?
          Hi, @alan-kilobrn and All,
          Many thanks for this new enhanced version !
          Before speaking about my tests of your 2nd try, I re-read all the discussion and tried to play with your first version !
          • So, regarding this first version :
          I decided to search for the word license, program and version in the N++ license.txt file. And, strangely, I did not get all the expected matches ! After a while I understood that you must have the focus on the file containing the list of words ( which are searched in the current file of the other view ). In that case, the results are quite correct !
          But if the focus is on the file being analyzed, the script seems to match only the first two matches ?!
          Now, regarding your second version :
          • Thanks, first, for bookmarking all the lines containing the matches
          • Thanks also the possibility to search for multiple-words expressions such as Bob and Carol or, even, complete sentences !
          • Finally, thanks for supporting the regex expressions. For instance, if you have a one-line file containing Bob.*?Carol, it would mark, in the current file of the other view, all the smallest ranges of characters beginning with Bob till Carol, with this exact case !
          • Note that the Python search is sensible to case, by default and does not care about the whole word notion. So :
            • To run a search insensible to case, just prefix your regex or expression with the (?i) modifier
            • To run a search which matches only whole words, surround your expression with the \b assertion. For instance, the regex search \bted\b would find the first name ted but not the string ted in the word deleted
          Now, Alan, I’m sorry but it’s time to talk about some inconveniences ! I take up your text with Bob, Carol, Ted and Alice :
          Imagine I have this two-lines list :
          \bBob.{2,20}Carol\b
          \bTed.{2,20}Alice\b
          • If the focus is on that list, the script correctly marked all the zones in red but no bookmarking occurs ! Oddly, it bookmarks the virtual final line of the list, instead !
          • If the focus is on the file being analyzed, the script correctly bookmarks all the lines where the zones belong but, strangely, it red-marks, only, the first two matches as with your 1st script !?
          I’m sure you won’t be long to find out a solution to these problems !
              Alan Kilborn @Alan Kilborn
                Hello @alan-kilborn,
                So, magically, the second version of your script seems to work better, this morning ;-))
                However, there’s still this minor bug, as I said in my previous post :
                Surely a matter of minutes to get it right !
                Note that I can live with this : we just have to remember to focus on the view contening the list of words/regexes, before running your Python script !
                  @guy038
                  So somewhere between writing the first version of the script, and the changing of it to create the second script, I decided that it made sense to require that the “data” file you want the markings to be shown in should be the active file in the primary view, and the “list” file of tokens/regexes that should be used to do the markings should be the active file in the secondary view, when the script is run. It is an unwritten requirement (except that I just wrote it!).
                  The first version of the script, because it was simpler and only one “word” was expected per line in the “list” file, tried to determine which view contained which.
                  Aside from that, with the second version of the script, I’m not seeing the problems you mention. Can you give an exact example that replicates the behavior?
                    Hi, @alan-kilborn,
                    For instance, with :
                    • Your text pasted, in new 1, in the main view
                    • A list of four first names, pasted in new 2, in the secondary view
                    • Cursor at the very beginning of new 1
                    • Focus on new 1 ( the text )
                    After running the script, I got :
                    As you can see, all bookmarks are here, but some red marks are missing ! The script seems to only red-mark the first occurrence of each word of the list !
                    In contrast to :
                    • Your text, pasted in new 1, in the main view
                    • Cursor at the very beginning of new 2
                    • Focus on new 2 ( the list )
                    This time, everything went fine !
                      @guy038
                      I think I remember something about possibly Notepad++ code itself interfering with scripts that are trying to use indicators?
                      Perhaps the code in the script that “selects” an indicator needs to be “tighter” to where the indicator is used?
                      Maybe try changing these lines of the script:
                                  for m in matches:
                      to this instead, and see if it runs differently?:
                                  for m in matches:
                      (really what this means is just moving the “setting” of the indicator inside the loop, so that it is definitely set each time before a range is “filled” with it)
                      Let me know how that goes.
                        @alan-kilborn,
                        BINGO ! It works like a charm, whatever the focus is ( The main or the secondary view ) ;-))
                        You’re right : placing the indicator’s definition inside the loop is the key point !
                        Many thanks, again, for your cooperation :)
                        Just to be sure : did you reproduce the issue, too, when focus is in the analyzed text view ?
                          @guy038 said in Bookmark multi words from multi lines in a text:
                          Mostly it worked okay for me on simpler data sets.
                          But I noticed it as an issue when I was looking into a larger-dataset problem, e.g. THIS ONE, and that made me recall an issue where an indicator needs to be set right before a fill, even though the indicator was set earlier and still should remain set.
                          • prahladmifourP
                            prahladmifour
                            Hello,@BAZ-BAZOOO
                            Please follow this information, To Bookmark multi words from multi lines in a text
                            Find What:
                            (.Query . message.\R.ApplicationGatewayID = 5009.\R.\R.\R)|^(?!.Query . message).\R?
                            Replace With:
                            $1
                            The regex is of the form:** (<YOUR_REGEX_MATCHING_LINES>)|^(?!.<STARTING_PART_OF_REGEX>).\R?.**
                            Description:
                            • (.Query . message.\R.ApplicationGatewayID = 5009.\R.\R.*\R) - a line with Query and then message words on it, then the next line that has ApplicationGatewayID = 5009 on it and then 2 more lines, captured into Group 1 ($1 refers to this value)
                            • | - or
                            • ^(?!.Query . message).*\R? - start of a line (^) that has no Query and then message on it, then the whole line and optional linebreak after it are matched and eventually removed.
                            I hope this information will be useful to you.
                            Thank you.
                            1 Reply Last reply Reply Quote -3
                              The marker ID used for bookmarks changed in Notepad++ 8.4.6 (and later). It is now 20, instead of 24. So, all references to 24 in this thread and/or its script(s), should be changed to 20.
