    What is the cross-hatching for? (Style Configurator)
    24 Posts 5 Posters 7.3k Views
      Hello, @michael-vincent, @ekopalypse, @alan-kilborn, and All,
      @alan-kilborn said :
      It might be the thing that finally kicks me over the hump to stop using the default theme. :-)
      Me, too !
      Best Regards
        Let me think about it.
          PeterJones @Ekopalypse
          @Ekopalypse said in What is the cross-hatching for? (Style Configurator):
          0 = default foreground and background
          1 = default background
          2 = default foreground
          Thanks for that. I hadn’t known either about the right click or the colorStyle attribute values (neither was previously officially documented)
          PR#81 for preferences docs include describing the right-click on the color box to get the same behavior.
          Docs PR#82 includes describing that behavior in both the configuration files details and in the UDL (same attribute values in both).
            @PeterJones said in What is the cross-hatching for? (Style Configurator):
            and in the UDL
            And in case you didn’t know, my experiments show that the “inherit from default” for UDL inherits from the Style Configurator > … >Default Style colors, not from the UDL > Default Style: > Styler. I made sure to document that.
            And also found a bug in the UDL color box slash indicators.
            So this discussion prompted two PRs and a bug report so far. Thanks. :-)
              Thanks for that.
              in case I wasn’t clear, thanks to everyone in this thread, who all contributed to the understanding.
                And there’s more to come yet:
                @Ekopalypse said:
                I thought about creating a python script based on the stylers.xml to
                bring all themes to the same level
                Hopeful cross-link?: https://community.notepad-plus-plus.org/post/52587
                  Hello @peterjones, @alan-kilborn, @ekopalypse, @michael-vincent, and All,
                  I have not migrated to v7.8.6, yet. However, I noticed, since a very long time, the bug you mentioned, Peter, in the link below :
                  https://github.com/notepad-plus-plus/npp-usermanual/pull/81#issuecomment-614183652
                  To produce that issue, where both the background and foreground colors are available, where only one should be :
                  • Start Notepad++ ( I did this test with the release v7.8.5 )
                  • Run for instance, Settings > Style configurator
                  • Verify that the Default ( stylers.xml) theme is selected
                  • Select the Global Styles language
                  • And select, for instance, the Mark Style 1 style
                  • By default :
                    • The foreground color is not available and its color is a light grey
                    • The background color is available and its color is a light blue ( 0,255,255 )
                  • Now, switch from the Default ( stylers.xml) theme to the next Bespin theme
                  • And switch back, immediately, to the Default ( stylers.xml) theme
                  • Re-select the Mark Style 1 style
                  • This time :
                    • As before, the background color is available and its color is a light blue ( 0,255,255 )
                    • But, the foreground color is, now, available and its color is a dark red ( 204,0,0 ) ??!!
                  Best regards,
                    PeterJones @guy038
                    @guy038 ,
                    Weird. When I use my normal v7.8.5 portable, it never shows Global Styles > Mark 1 with greyed foreground. If I take a fresh v7.8.5 portable, it does start with Mark 1 greyed, and if I follow your path to Bespin and back, it gets ungreyed when I’m back in default sylers.xml.
                    Weird.
                      Hello, @peterjones, and All
                      I just redid the test of my previous post, with :
                      • A new fresh dezipped 32 bits portable version of N++ v7.8.5 in a folder, without any additional plugin other than default ones
                      • The new dezipped 32 bits portable version of N++ v7.8.6 in an other folder, that I haven’t downloaded, yet
                      And I confirm the previous behaviour, with the two colors available, both for v7.8.5 and v7.8.6
                      Mauy be, once more, it could be only related to my Win XP configuration ?
                      BTW, to get the initial colors and default behaviour of the Style Configurator, simply, stop and restart Notepad++
                        I can confirm the behavior.
                        But like @PeterJones, I see that only with a fresh version,
                        not with my regular version.
                        With a fresh version I see the following:
                        disabled 	Tag
                        		Global override
                        		Default Style
                        		Indent guideline style
                        		Brace highlight style
                        		Bad brace colour
                        fg 		Current line background colour
                        fg 		Selected text colour
                        bg 		Caret colour
                        bg 		Edge colour
                        		Line number margin
                        		Fold
                        bg 		Fold active
                        		Fold margin
                        bg 		White space symbol
                        fg 		Smart HighLighting
                        fg 		Find Mark Style
                        fg 		Mark Style 1
                        fg 		Mark Style 2
                        fg 		Mark Style 3
                        fg 		Mark Style 4
                        fg 		Mark Style 5
                        fg 		Incremental highlight all
                        fg 		Tags match highlighting
                        fg 		Tags attribute
                        bg 		Active tab focused indicator
                        bg 		Active tab unfocused indicator
                        bg 		Active tab text
                        		Inactive tabs
                        bg 		URL hovered
                        Now, if I change to Bespin theme and back
                        all but “Mark Style 2” are enabled.
                        But if I do the same test with Choco theme,
                        then all of them, including Mark Style 2, will be enabled.
                        I haven’t tested with other themes.
                          Alan Kilborn @Ekopalypse
                          Can you clarify what this means?
                          Same actual version numbers of Notepad++, just a freshly extracted one versus the one you use day-by-day (where maybe you’ve upgraded configuration files manually bit by bit)?
                            Ekopalypse @Alan Kilborn
                            fresh version = portable, downloaded from npp without any modifications and additional plugins
                            regular version = my portable version - highly customized and with additional plugins
                            Test was done with npp 7.8.6 (fresh) and 7.8.5 (regular).
