    Multi-cursor editing
    53 Posts 8 Posters 13.9k Views
      @astrosofista @Alan-Kilborn
      Thanks for testing and improving.
      I haven’t noticed it yet but it makes sense.
      The documentation for searchFlags is described here.
      Alan KilbornA astrosofistaA 2 Replies Last reply Reply Quote 2
        Alan Kilborn @Ekopalypse
        @Ekopalypse said in Multi-cursor editing:
        Yes but that documentation falls flat when you need an actual number to pass to a function!
        Is there some Python magic one can do to find these identifiers? What I mean is, if I do dir(MENUCOMMAND) in the P.S. console, I see:
        >>> dir(MENUCOMMAND)
        ['CLEAN_RECENT_FILE_LIST', 'EDIT_AUTOCOMPLETE', 'EDIT_AUTOCOMPLETE_CURRENTFILE', 'EDIT_AUTOCOMPLETE_PATH', 'EDIT_BEGINENDSELECT', ...
        Some similar way of finding these “SCFIND_” things?
          Ekopalypse @Alan Kilborn
          for readability you normally use FINDOPTION.NONE instead of the 0.
          In order to get all values from such enum you can call its values method.
          For example: FINDOPTION.values() would return
          {0: Npp.FINDOPTION.NONE, 1048576: Npp.FINDOPTION.WORDSTART, 2: Npp.FINDOPTION.WHOLEWORD, 4: Npp.FINDOPTION.MATCHCASE, 2097152: Npp.FINDOPTION.REGEXP, 8388608: Npp.FINDOPTION.CXX11REGEX, 4194304: Npp.FINDOPTION.POSIX}
          Alan KilbornA 2 Replies Last reply Reply Quote 2
            Yes, but you have to know that EXISTS first! :-)
            To your point about “readability”…that’s why I was asking.
            I would much rather NOT use the magic number of zero.
            I didn’t see anything that logically links FINDOPTION to the SCFIND nomenclature. Maybe I missed the connection.
              Just a slight note for any future readers:
              FINDOPTION.values() at the Pythonscript console yields:
              >> FINDOPTION.values()
              Traceback (most recent call last):
                File "<console>", line 1, in <module>
              TypeError: 'dict' object is not callable
              The proper thing to do is FINDOPTION.values (no parentheses).
                Ooopps - you are right, thx for reporting.
                Seems I have wrapped it incorrectly with my python3 plugin.
                Yes, not every enum has really the same, but most of the time similar, name as the normal c-headers have.
                To get all the enums you can run globals() in the console or from a script.
                  my python3 plugin.
                  gimme, Gimme, GIMME! :-)
                    I’m sorry, but it’s still an alpha version.
                    As long as not all functions/methods work as described
                    you’re not really gonna enjoy it.
                    Had a nasty plugin crash yesterday because instead using
                    an signed integer I used an unsigned one. :-(
                    But there will be fewer and fewer open issues.
                    And since I was wrong with the release date several times,
                    I prefer not to give a forecast until when a beta version can be expected.
                    The actual situation, Corona, has one advantage - I have more time to work on PySnack (That’s what I want to call it).
                    • astrosofistaA
                      astrosofista @Ekopalypse
                      Glad to be of help. Let me know if more tests are needed.
                      Best Regards.
                        Michael Vincent @dail
                        @dail said in Multi-cursor editing:
                        I use BetterMultiSelection
                        As do I - along with SurroundSelection and DoxyIt. Do you still support DoxyIt, I submitted a pull request a little while back.
                        dailD 1 Reply Last reply Reply Quote 0
                        • dailD
                          dail @Michael Vincent
                          @Michael-Vincent
                          Personally I haven’t used DoxyIt in years. I wouldnt say it’s not supported, just my interest is quite lacking.
                          In light of recent circumstances I find myself with copious amounts of free time currently, so I will make it a point to take a look at your PR soon.
