    Regex] Rounding numbers python script does not run properly
    28 Posts 4 Posters 4.1k Views
      Ekopalypse @Alan Kilborn
      one idea might be to search for matches and replace only those which are
      in the same range as the selected text. Something like
      if start_pos_selected text <= match_start and end_pos_selected_text >= match_end:
          replaceSelText
      Or did I misunderstood your goal? :-(
        Alan Kilborn @Ekopalypse
        Maybe that part. :)
        To be able to offer a preview of the yet-to-be-done replacement, I need to know what that replacement will be. I can’t do that without actually doing the replacement. Catch-22. I could do it and then undo it, I suppose, but that gets messy. Mostly it should be OK, but sometimes with regexes Boost can differ from Python’s re.
          what about using a hidden scintilla instance?
            That also sounds “messy” (or “involved”) but if you have some snippet to show me it is not so bad…?
            EkopalypseE 2 Replies Last reply Reply Quote 0
              I used it here.
                just be careful about notepad.destroyScintilla(self.hidden_scintilla)
                Currently npp crashes when using this and then request another buffer.
                There is already a merged fix but only available on next release.
                  @Ekopalypse
                  This is the issue, I assume: https://github.com/notepad-plus-plus/notepad-plus-plus/issues/4487
                    correct, that is the one.
                      So, like this: hidden = notepad.createScintilla()
                      That is actually a nice solution. The hidden instance’s entire text can be set to the matched text from the editor.research(). Then the hidden.rereplace() can be called and the result of the replacement read out into a Python string variable. Thanks, Eko; clearly I would not have thought of this technique without your pointer.
                      just be careful about notepad.destroyScintilla()
                      This is not a problem as I will do this near the top of the script, and never do a “destroy”:
                      try:
                          hidden
                      except NameError:
                      Alan KilbornA EkopalypseE 2 Replies Last reply Reply Quote 2
                        Alan Kilborn @Alan Kilborn
                        There really is an “echo” in here, or just me repeating myself and not noticing.
                          :-D never ever - don’t even THINK about it unless your npp version is > 7.7.1 :-D
                          I guess, hidden.rereplace() is enough if you keep the text from editor and hidden in sync.
                          The replace function gets a match object which contains the position of the text to be replaced so from the replace function you could start the dialog, or?
                            @Ekopalypse
                            No, I’m not trying to “parallel” the text in the real editor and the hidden. If I set as the hidden editor’s entire text the match from the search, doing the replace on that guarantees the replace will succeed and the entire text left in the hidden editor’s buffer will be the replacement preview text. Long to explain but it seems to work.
