pythonscript: saying that encoding is not defined.
I downloaded portable editions of 7.6.1-32, 7.6.1-64, 7.6.2-32, and 7.6.2-64. I manually installed PythonScript 1.3.0.0 into all four portable installations.
I ran the two scripts I just showed in all four instances. In all four, the version with
# encoding=utf-8worked, and the version with# encoding =utf-8failed.In 7.6.2-64, I then edited the two scripts to use
codinginstead ofencoding:# coding =utf-8 from Npp import console console.show() console.clear() console.write( u'SMILE: ☺\n' ) console.write( u"क़" )This version failed with the same error.
And the “correct” version:
# coding=utf-8 from Npp import console console.show() console.clear() console.write( u'SMILE: ☺\n' ) console.write( u"क़" )passed, as it did with
encoding.Using the encoding lines that are coming through your forum-markdown badly formatted, I cannot reproduce your problem. The only ways I can reproduce your error message are to put a space between
codingand=, or by not having the encoding line.It is not a problem with PythonScript 1.3.0.0. It is not a problem with my portable versions of 7.6.2 for either 32bit or 64bit.
Either the text you are quoting is getting mangled – in which case, you will have to correctly use markdown to avoid it getting mangled – or you are doing something else wrong, or there is something else unique about your setup that I cannot reproduce in my portable setup.
Complete ? > Debug Info for 7.6.2 64bitNotepad++ v7.6.2 (64-bit) Build time : Jan 1 2019 - 00:02:38 Path : C:\usr\local\apps\npp64.7.6.2\notepad++.exe Admin mode : OFF Local Conf mode : ON OS : Windows 10 (64-bit) Plugins : DSpellCheck.dll mimeTools.dll NppConverter.dll PythonScript.dll -
I see that you were also trying without the hyphen in
utf8and with a colon instead of an equal:# coding:utf8 from Npp import console console.show() console.clear() console.write( u'SMILE: ☺\n' ) console.write( u"क़" )that one with
# coding:utf8(no space before the colon) passed# coding :utf8 from Npp import console console.show() console.clear() console.write( u'SMILE: ☺\n' ) console.write( u"क़" )The one with
# coding :utf8(with the space before the colon) failed.Try again with no space between
#andcoding, and a space after the colon:#coding : utf8 from Npp import console console.show() console.clear() console.write( u'SMILE: ☺\n' ) console.write( u"क़" )with
space colon space, it fails#coding: utf8 from Npp import console console.show() console.clear() console.write( u'SMILE: ☺\n' ) console.write( u"क़" )With
nospace colon space, it passes.I cannot get the error with the lines you say you are trying. Sorry.
[these four attempts were still with 7.6.2 64bit portable, as above]
your last script gave this output on cosole.
SMILE: ☺
क़it is correct. so it seems that encoding is not the problem.
thanks for you putting so much time and effort.
it worked.
I had put
editor.beginUndoAction()
#coding:utf8in my file. meaning coding was not on the first line.
how I put coding in the first line.
#coding:utf8
editor.beginUndoAction()the error stopped and it did the required change in my text file.
I can still say that the previous version was working ever since, but stopped working after I switched to 64 bit and new version.
maybe, that had change some python version or something that had been causing the error.
Thanks a lot for guiding me step by step to solution.
I’m glad you found the problem.
Per PEP 263, “To define a source code encoding, a magic comment must be placed into the source files either as first or second line” (emphasis added). That has been true since Python 2.3 in 2001, so it wasn’t a recent change in the Python library. (Besides, since I started using PythonScript a few years ago, they haven’t changed from Python 2.7). I am not sure how it ever would have worked on the third line for you. But the important thing is that you now know it needs to go on the first or second line of your file. -
@V-S-Rawat said:
This is my entire script
#coding=utf8The real problem likely could have been found in like 3 seconds if you would have ever learned how to present code via correct markdown on this forum.
Scrolling back quickly thru all of the postings shows that only Peter’s code replies use the black-box markdown.
You are right. it troubled all of you and took your time and effort.
It had caused problem to me also that while the script was not working, I had to find a way around and I had to create a foxreplace for those sets of character, and put everything every time there to do the conversion.
I don’t know why this site is giving so complicated method of posting.
what you said ’ ’ ’ will format quote, is not appearing anywhere in the toolbar that appears at post writing.just four icons appear in toolbar, bold/ italic are understood, 4th could be link, what is 3rd, (like details in windows) is not clear,
I fear to click at those icon because they might delete my post written so far.even mouse hover tool tip is not appearing on them.
there is no option for image posting,
there is no option for code-posting.At least they can just give a plain text option of posting, instead of so many categorizations.
or if such an option is available somewhere deep in setting, please guide me to that.
site developer should study other sites how simple their post formatting aids are.
Thanks.
I agree it could be better.
feel free to contact the developers of nodebb here ;-)
but the best thing is if you would read the posts you have been given.
i quote @PeterJones : … the help can be found by clicking that ? in the COMPOSE window, or by following the link I posted above which gives an excellent summary of how to use markdown in the forum …
first the ? will lead you to this complete manual on how to markup everything
second, he took the extra time to extract and post what is relevant for you with an extra explanation and examples, but you sometimes seem to be too stubborn to read or try to understand what people tell you.
please participate, if you want to get your problems solved.
Yes but quite frankly that sucks. :D
This is a very common problem here; reminds me much of the OP in this thread: https://notepad-plus-plus.org/community/topic/16840/the-strange-behavior-of-the-cursor-in-the-notepad-window
