    Stuck in "Administrator" mode...how to get out?
    35 Posts 10 Posters 11.9k Views
      I tend to upvote good answers, or replies that ask questions I think are worth asking, or replies that directly and informatively answer those questions or add useful information to a discussion: knowing that having UAC enabled does not fix it for you is useful to the discussion – it says that “well, we haven’t yet found the root cause”. It’s unfortunate, but it still helps move the thread forward.
      • Meta ChuhM
        Meta Chuh moderator @Alan Kilborn
        i second that.
        i gave you an upvote on your screenshot, because you actually took the time to do so.
        of course it doesn’t solve your issue and no one thinks it’s solved just because you got the slider way up and posted it, and for you it’s probably a natural thing to participate to get issues solved, but you’ve seen for yourself how few people do the same and keep reposting the same thing over and over again without trying anything suggested.
        i simply had to give you an upvote for it, it’s in my nature ;-)
          Thanks for everyone’s efforts so far…
          • Meta ChuhM
            Meta Chuh moderator
            you can’t imagine how hard it was for me to keep my finger off that upvote button right now 😂😂😂 ;-)
            • Ilkka LindblomI
              Ilkka Lindblom
              Re-enabling UAC fixed this issue for me. Unfortunately, probably due to all the uninstalls and reinstalls I made while trying to fix it, NPP seems to have lost my saved session. Still I’m glad to have it working again, so thanks a lot people.
              Meta ChuhM 1 Reply Last reply Reply Quote 3
              • Meta ChuhM
                Meta Chuh moderator @Ilkka Lindblom
                side note to @Alan-Kilborn, as this thread was resurfaced by @Ilkka-Lindblom :
                i guess my evil upvote finger’s incubation period for “Thanks for everyone’s efforts so far…” is over.
                my hooked, crooked finger just went haywire on that damned button … and i sincerely hope you won’t notice it at all 😉
                  So an update to this thread…
                  I’m still in Notepad++ 7.5.x land for my day-to-day Notepad++ usage, but recently I had reason to grab a portable 7.6.4…and I noted that running this one it DOES NOT end up in Administrator mode. By this I mean no [Administrator] in the title bar, and able to drag-n-drop files from a non-admin Explorer window.
                  So just a little nicety waiting for me when I get around to making the Plugin Mgr -> Plugin Admin chasm jump! :)
                  I don’t know what changed in N++ so that this now happens, but I’m going to mark this thread SOLVED if I can.
                  • Meta ChuhM
                    hi @Alan-Kilborn
                    aaahhhhh … the upvote thread, lol
                    i love revisiting things like these 💚
                    i’ve got a big smile on my face right now 😃
                    ps:
                    very intriguing … if 7.6.4 and above don’t trigger administrator mode, but 7.6.3 and below do, could it be that it gets triggered by the existence of a code signing cert on the older versions on your system ?
                    i have never heard about a behaviour like this if something is code signed, but 7.6.4 was the first release without windows code signing. ⁉️
                      Alan Kilborn @Meta Chuh
                      @Meta-Chuh
                      I did not do exhaustive testing, but I just went back and tried 7.6.3 and 7.6.2 portable versions. Both of these showed [Administrator] in the title bar. Trying 7.6.4 again…still no [Administrator] there! :)
                      • anselme16A
                        anselme16
                        good lord the source code determining if the application should launch in administrator is ugly.
                        here is a clarified version of it :
                        Notepad_plus::Notepad_plus()
                        :   _isAdministrator (false)
                            // Determine if user is administrator.
                            winVer ver = NppParameters::getInstance()->getWinVersion();
                            if (ver >= WV_VISTA || ver == WV_UNKNOWN)
                                SID_IDENTIFIER_AUTHORITY NtAuthority = SECURITY_NT_AUTHORITY;
                                PSID AdministratorsGroup;
                                if(AllocateAndInitializeSid(&NtAuthority, 2, SECURITY_BUILTIN_DOMAIN_RID, DOMAIN_ALIAS_RID_ADMINS, 0, 0, 0, 0, 0, 0, &AdministratorsGroup))
                                    BOOL isAdmin;
                                    if(CheckTokenMembership(NULL, AdministratorsGroup, &isAdmin))
                                        _isAdministrator = isAdmin;
                                    FreeSid(AdministratorsGroup);
                        Sorry i couldn’t resist.
                          I’m confused – why is it ugly? Looking at the existing code (below) I’m struggling to see any significant ugliness or even any real differences between it and your version:
                              BOOL is_admin;
                                  is_admin = AllocateAndInitializeSid(&NtAuthority, 2, SECURITY_BUILTIN_DOMAIN_RID, DOMAIN_ALIAS_RID_ADMINS, 0, 0, 0, 0, 0, 0, &AdministratorsGroup);
                                  if (is_admin)
                                      if (!CheckTokenMembership(NULL, AdministratorsGroup, &is_admin))
                                          is_admin = FALSE;
                              else
                                  is_admin = false;
                              _isAdministrator = is_admin ? true : false;
                          • Alex BoyceA
                            Alex Boyce
                            I have also experienced this issue and I was able to resolve it.
                            First, I got into this situation with Notepad++ itself. I tried to edit a file in the Program Files tree and was prompted by Notepad++ that I needed to be in admin mode to do that and did I want to restart Notepad++ in admin mode. I clicked Yes and have been in admin mode ever since.
                            As noted above, drag and drop from a non-admin explorer doesn’t work, but the context menu Open with Notepad++ does, so it wasn’t too much of a hardship. However, it is annoying, so I tried to find out how to turn it off. There is no setting within Notepad++ for it, nor is the compatibility mode tab on the properties sheet checked.
                            I did a google search and found this thread. One of the suggestions was to search the registry for Notepad++. I tried this and found the magic key. Under HKCU\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatability Assistant\Store there was a value named C:\Program Files\Notepad++\notepad++.exe. I deleted this value and restarted Notepad++ and it is in normal mode again.
                            I have been able to repeat this by dragging a file from the Program Files tree into Notepad++ which works fine, but when you try to save it, the reopen in admin mode prompt appears.
                            Thanks for the help.
                            EkopalypseE 1 Reply Last reply Reply Quote 4
                              Ekopalypse @Alex Boyce
                              @Alex-Boyce
                              thx for the information.
                              Because you ended with Thanks for the help. I’m unsure if you expect an answer
                              on an implicit question, which I was not able to identify (non-native speaker).
                                Similar discussion relating to the original topic here is continued IN-THIS-THREAD …
