    New Plugins Home (where Notepad++ will load from)
    79 Posts 22 Posters 132.9k Views
    • donhoD
      donho
      Edit (03 December 2018): Add new plugin list location - it’s not in %APPDATA%\plugins\Config\ anymore
      Edit (28 November 2018): the following plugins loading schema has been modified.
      Note that Notepad++ won’t load plugins from: %LOCALAPPDATA%\Notepad++\plugins\ anymore.
      This table should clarify the location of Notepad++'s plugins.
      1. Notepad++ installed on: %PROGRAMFILES%\Notepad++\ or wherever without doLocalConf.xml
        Plugins loaded from: %PROGRAMDATA%\Notepad++\plugins\
        Plugins list full path : %PROGRAMDATA%\Notepad++\plugins\Config\nppPluginList.dll
        Plugins’ config dir for user data: %APPDATA%\plugins\Config\
      2. Notepad++ installed on: wherever (except in %PROGRAMFILES%\Notepad++\) with doLocalConf.xml
        Plugins loaded from: <NPP_INST_DIR>\plugins\
        Plugins list full path : <NPP_INST_DIR>\plugins\Config\nppPluginList.dll
        Plugins’ config dir: <NPP_INST_DIR>\plugins\config\
      A message NPPM_GETPLUGINHOMEPATH has been added from v7.6 to retrieve the plugin home path.
      Use NPPM_GETPLUGINSCONFIGDIR to get user plugin config directory path to save/load plugin parameters for current user.
      Meta ChuhM 1 Reply Last reply Reply Quote 7
      • Meta ChuhM
        Meta Chuh moderator @donho
        @donho
        thanks for 3. %ALLUSERSPROFILE% in the next release
        but 2. is not correct, at least not the part “installed on: wherever”
        doLocalConf.xml will still be ignored if np++ is installed or copied to %PROGRAMFILES%
        ways to reproduce:
        notice: %LOCALAPPDATA%\Notepad++\plugins\ has to be empty before testing, or you will see those plugins
        method 1:
        put the portable version npp.7.6.bin.zip manually into the C:\Program Files folder, start and the plugins dissapear, no plugin is shown.
        as soon as you move this same portable version folder out of Program Files, eg. to the desktop, and start Notepad++.exe all plugins are shown
        method 2:
        install to the default folder C:\Program Files\Notepad++ with the option “Do not use %APPDATA%” selected.
        even though a doLocalConf.xml has been created, notepad++ will not show any plugins, nor the plugins admin.
        i’ve tested all releases, x86 and x64
        • SinghRajenMS
          SinghRajenM moderator
          @donho have a look here.
          I feel we need to consider case where people use common PC. So user choice should be honored. If all the plugins go to %ALLUSERSPROFILE%, then it will be available to all. But some user may not want a particular plugin and may uninstall it which will impact other user on the same machine.
          • donhoD
            donho @Meta Chuh
            I do understand the need. However, there’ll be some situation which make Plugins Admin behaviour inconsistent:
            If the same plugin foo.dll is in 2 different locations, %ALLUSERSPROFILE%\Notepad++\plugins\foo\foo.dll and %LOCALAPPDATA%\Notepad++\plugins\foo\foo.dll
            Notepad++ should load only one (let’s say the one in %LOCALAPPDATA%). If user removes this plugin by using Plugins Admin, after restart, the one in %ALLUSERSPROFILE% will be loaded by Notepad++ - user will be confused.
            So the best behaviour (to me) is loading plugins only from one location.
            @Meta-Chuh Sorry, I wasn’t clear. I just updated the content.
            SinghRajenMS 1 Reply Last reply Reply Quote 1
            • pnedevP
              pnedev
              @donho ,
              What about removing the plugin from both places in this case?
              Or refusing to install it locally for the user if it is already installed for all users?
              • MAPJe71M
                MAPJe71
                Alternative solution:
                1. Don’t allow installation in %LOCALAPPDATA%\Notepad++\plugins\ when plugin/dll already available in %ALLUSERSPROFILE%\Notepad++\plugins\ i.e. allow only one installation location.
                2. When duplicate plugins are detected (e.g. manually installed by user in %LOCALAPPDATA%\Notepad++\plugins\), load the one that is favorite (e.g. configuration option named UserProfile with value All or Current).
                Furthermore, it would be nice/helpfull when the PluginAdmin has a column indicating where each plugin is installed e.g. AllUsers or %UserName%.
                • SinghRajenMS
                  SinghRajenM moderator @donho
                  @donho
                  I feel this can be handled easily.
                  1. Always, give preference to user location (preferably %appdata% over %localAppdata%), than the global location which can be %allusersprofile%.
                  2. All default plugin can go to global location.
                  3. New plugin installation should go to user location. Even update of an existing plugin should go to user location only. Because Npp will give preference to user location always as per #1.
                  4. If user tries to remove a plugin then
                  • if plugin present only in global scope (e.g. %allusersprofile%), then don’t actually remove a plugin, rather mark it in ignored list. This list should be maintained in user scope. It can be written either as config file somewhere in %appdata% or in HKCU. %appdata% is preferred as it can roam from PC to PC for domain users.
                  • if plugin present in both user and global scope, then remove the plugin from user scope and mark it in ignore list as well so that loading from global scope will be avoided.
                  • dinkumoilD
                    dinkumoil
                    @donho
                    What will be the location for nppPluginList.dll?
                    • dinkumoilD
                      dinkumoil
                      @donho
                      When plugin authors want to update a plugin they have to change the related entry in the plugin list. Thus they need the ability to test if this entry works correctly.
                      Since the nppPluginList.dll file can not be changed we need another approach. What are your ideas/plans concerning this point?
                      • pnedevP
                        pnedev
                        I like this idea of yours. It is an efficient way out of the problem where user A doesn’t want particular plugin and by removing it removes it for all other users as well.
                        But the approach to install and prefer always the user version of a plugin is two-folded. It depends on the way you look at it.
                        If you look from an administrator’s perspective you might want the users to access specific set of plugins (including specific versions) that are known to be safe and the possibility for a user to overwrite your secure version with his custom one is a nightmare. You can see @Fran-Favorini 's post here.
                        • donhoD
                          donho @dinkumoil
                          @dinkumoil
                          There is no impact for plugins location or am I missing somethings?
                          They should always use the tools with the current plugin list. It should be enough for testing, shouldn’t it ?
                          • SinghRajenMS
                            SinghRajenM moderator @pnedev
                            @pnedev
                            Oh, I see. But even this also can be handled using config or registry whether to allow user to load/install/update plugin. This config can be written by providing an another checkbox on installer’s last page (just before finish), or can be pushed as group policy from domain users.
                            Otherwise, standard user will never be able to use any new plugin because s/he can’t write to %allusersprofile%. This way we are just blocking normal user to use full-fledged plugin managers even administrator does not set any policy explicitly. However, this statement is not validated, but I feel it is true in most of the cases. Correct me, if I am wrong.
                            • dinkumoilD
                              dinkumoil
                              @donho
                              The current discussion about how and where to install plugins has overlayed the questions in my comment. I wanted to have exact infos about these topics.
                              Maybe this is the wrong topic to ask this question. There was a discussion if the file maybe should be stored under %ProgramData% in order to make it available to all users. I wanted to know the current status of that discussion.
                              OK, question answered.
                              • donhoD
                                donho @dinkumoil
                                What’s your thought about it then?
                                • dinkumoilD
                                  dinkumoil
                                  I think it would be better to store it under %ProgramData%. A plugin list only available for that user who installed Notepad++ makes no sense, especially as in the future the plugins itself seem to get stored under %ProgramData% as well.
                                  • pnedevP
                                    pnedev
                                    I’m not quite familiar with that but your comment sounds perfectly reasonable to me.
                                    • donhoD
                                      donho
                                      The idea of plugins loading from both default / user folders is good (I said it and I say it again), but in order to avoid plugins management conflict and simplefy the implementation, I think it’s a nice-to-have but not a must-to-have feature. Therefore it won’t be implemented.
                                      • donhoD
                                        donho @dinkumoil
                                        @dinkumoil & @SinghRajenM :
                                        It’s a good idea to have one list for all users. However, the nppPluginList.dll is supposed to be updated independently. It means Notepad++ which is launched without Admin right cannot modify the data in %Programdata%. So plugin list cannot be in %Programdata% because it cannot be updated by users without admin right.
                                        Or you’ve got a solution for that?
                                        • mavelliM
                                          mavelli
                                          Notepad++ loads plugins from: <NPP_INST_DIR>\plugins
                                          is strictly needed if you are in an environement where the enterprise sets the MS Windows AppLocker to allow only binaries from a certain position or every binary needing a signature and everything is pre-packaged.
                                          in such an environment, users cannot install plugins themselves but every plugin needed by a user needs to be pre-packaged with NPP itself and then distributed to all.
                                          any idea how this can be achieved with 7.6? i am one of the NPP users in this environment and also responsible for the instructions how to package it.
                                          • dinkumoilD
                                            dinkumoil
                                            @donho
                                            If the file nppPluginList.dll gets stored under %ProgramData% I guess the exact path would be %ProgramData%\Notepad++\plugins\config\nppPluginList.dll.
                                            If plugins get installed under %ProgramData% the exact path would be %ProgramData%\Notepad++\plugins\<plugin-name>\<plugin-name>.dll.
                                            These would be two different locations. Thus it would be possible to change during installation of Notepad++ the NTFS access rights of the directory %ProgramData%\Notepad++\plugins\config to grant access to all users.
                                            The nppPluginList.dll doesn’t contain executable code and, I guess, it is loaded with the flags LOAD_LIBRARY_AS_DATAFILE | LOAD_LIBRARY_AS_IMAGE_RESOURCE, thus access rights for all users should not introduce any risk.
                                            BUT what’s about plugin installation? Storing plugins under %ProgramData%\Notepad++\plugins\<plugin-name> would also require elevated rights, a thing GUP.exe currently doesn’t do (maybe it is even not able to do).
                                            If we want plugins to be installed under %ProgramData% we need a GUP.exe that is able to trigger UAC when copying a files to a certain directory. Thus GUP.exe could be used to download and install nppPluginList.dll and plugins themself.
                                            Because GUP.exe isn’t able to provide user feedback during plugin installation I think it is necessary to extend this program anyway. The current version is too simple - too much KISSes ;-).
                                            Some thoughts from a higher point of view:
                                            As far as I know all these discussions about where and how to store plugins derive from the idea to publish a Windows Store App variant of Notepad++. Because Microsoft issued the policy that an UWP package has to be immutable it is not possible to change the content of an UWP app’s installation directory.
                                            BUT Microsoft has also issued the policy that files with executable code have to be stored under %ProgramFiles% because this location offers some sort of protection against malware attacks. Thus neither %LocalAppData% nor %ProgramData% is the right place for storing plugin DLL files.
                                            It seems like the author of the UWP package spec had not in mind that there could be UWP apps which provide a plugin interface, thus he brought us into a dilemma - it makes no difference where plugin DLL files get stored, as long as the location tries to fit the requirements of an UWP app the location is WRONG, because of the one or the other policy.
                                            How about declining the requests for a Notepad++ UWP app variant because of security concerns and because the whole concept of UWP apps is crap?
                                            There is a certificate protected SciLexer.dll and SHA-256 hashes of plugin ZIP files to prevent malware and man-in-the-middle attacks but DLL files get stored at unsecure locations - it’s a paradoxon.
                                            donhoD 2 Replies Last reply Reply Quote 4
