    Right Justifying Paragraphs
    24 Posts 6 Posters 9.3k Views
    • hoji afzalH
      hoji afzal
      I wish Notepad++ had this feature.
      CodeWright used to have it and was very useful in organizing code.
      This is what it could do:
      1. Suppose you wrote these code lines:
        int argument1 = 1;
        int multiplier = 100;
        double weight = 200.345;
      2. Using this feature you end up with this:
        int argument1 = 1;
      To do it:
      a. Select the entire paragraph and use right justify from the context menu.
      b. Enter random number of spaces just before the = signs.
      c. Select the paragraph again and this time left justify it.
      d. Only select the = sign and every to the right of it and select left justify.
      that’s all
        Unfortunately, you didn’t Markdown your your example data quite right (you need to keep a blank line between the outline row and the indented data; also, you would have to have double the indentation to make it render as embedded text to account for the first level of indenting for outline, and the second for preformatted-text). You can see “exactly” how it will render by looking at the preview pane to the right of the edit frame. (“exactly” in quotes, because it doesn’t render @-mentions, and I’ve seen it occasionally stop rendering right on large posts). More on formatting at this help-with-markdown post
        Regarding your problem, if I understand correctly, you don’t actually want to right-justfiy – what it sounds like is that you want to align a second column based on the = character. ie, changing:
        int argument1 = 1;
        to
        int argument1   = 1;
        (though I may have missed a secondary justification in there)
        If that’s a correct interpretation, then the discussion in this thread, which is about aligning a column to a specific character. (In the old days, on 32bit, you could use the TextFX plugin; but that plugin has fallen by the wayside in terms of support, and doesn’t (i believe) have a 64bit version.) So if you have 32bit, you can install TextFX and use the Line up multiple lines by …. Otherwise, you can try to make the PythonScript alternatives work for you.
        hoji afzalH 1 Reply Last reply Reply Quote 2
        • dinkumoilD
          dinkumoil
          There is a plugin called “Code alignment” which is available as 64 bit version too. Have a look into Plugin Manager. It’s a tiny useful thing.
          • hoji afzalH
            hoji afzal
            @hoji-afzal
            Hi, thanks for your attention. I did notice the formatting in my original post and tried to go back and edit it, but the site doesn’t seem to allow you to edit a post once it has been published.
            Thanks for the clarification.
            I tried to download “Code alignment” as suggested by dinkumoil, but I got a server error. I will try it again later.
            For the alignment action I was talking about, all you need is the mouse and the context menu. No other settings would be needed. I could send the steps in an illustration, but I can’t because the site does not allow attachments. Actually I never thought of plug ins, and maybe someone has already done it. I am waiting for the next update to Notepad++ to see if I could get PlugIn Manager, as I don’t have it now.
            Thanks very much.
              The site allows editing for up to 3 minutes after you submit your post.
              If the results I posted weren’t right, and it was too late to edit your original post, you could have tried posting the data again in your reply, following the advice I gave you.
              Screenshots: This forum doesn’t host images, but it is perfectly capable of displaying them. Upload your image to imgur.com or other similar site, and follow the image-embed instructions found in the help with markdown link I already pointed you to.
              You can get plugin manager here: download, unzip, and put the DLL in your plugins subdirectory of the notepad++ program directory (as it says on that page)
              Once you get plugin manager, you can easily grab both “Code Alignment” and “TextFX”, and see if either one works for you.
              Scott SumnerS 1 Reply Last reply Reply Quote 2
              • Scott SumnerS
                Scott Sumner @PeterJones
                The thing that gets me is there’s a damn preview pane right there as you are composing…what, do people think that when they hit Submit that things are somehow magically gonna look different from the Preview? If it doesn’t look like you intend then there must be a reason. Stop…and figure out why. (Grumpy week for me??)
                • dinkumoilD
                  dinkumoil
                  Sometimes we need to relax from PEBCAK…
                  • hoji afzalH
                    hoji afzal @dinkumoil
                    @dinkumoil
                    I finally got it. It can align easily using the = sign. But I am still trying to get it to align on space.
                    Thanks a lot!
                    • hoji afzalH
                      hoji afzal @Scott Sumner
                      @Scott-Sumner
                      Didn’t know it was that big a deal :)
                      • Scott SumnerS
                        Scott Sumner @hoji afzal
                        It’s not a big deal to express yourself in a clear and understandable manner, especially when you are asking for something in a feature request? Hmmm. :-)
                        hoji afzalH 1 Reply Last reply Reply Quote -1
                        • hoji afzalH
                          hoji afzal @PeterJones
                          In fact this is how I format my columns to separate different fields like a table does.
                          Before:
                          public byte PUSH = 1;
                          private const int STOP = 0;
                          public const double SECS_TO_START = 10;
                          public int SEPARATOR = 21;
                          After:
                          Once I figure out “align by space” I will create keyboard shortcuts for it since Notepad++ generously allows that.
                          Thanks.
                          • hoji afzalH
                            @Scott-Sumner
                            PeterJones understood what i said! Instead of complaining he showed me how to do it, which I appreciate.
                              To line up by a space, you would copy a space into the clipboard, then use TextFX > Edit > Line up … by (Clipboard Character). Oh, that seems to not work… and wouldn’t probably align things right anyway.
                              You might want to do a multi-step process:
                              1. RegEx FIND= (?=\w+ = \d+;), REPLACE= | (space, vertical bar)
                              2. Copy Vertical bar charcter
                              3. Line up by clipbboard character
                              4. RegEx FIND=\|, REPLACE= (space)
                              5. Line up by =
                                In your example data, it made SECS_TO_START= 10, which might not be what you want, so:
                              6. RegEx FIND== (just equal sign), REPLACE= = (space then equal sign)
                              • chcgC
                                chcg
                                If it is just about how the visual aspect, maybe you want to try https://github.com/dail8859/ElasticTabstops (further explanation here http://nickgravgaard.com/elastic-tabstops/)
                                • dinkumoilD
                                  dinkumoil
                                  @hoji-afzal
                                  Seems like you are an “extreme aligner”… ;-)
                                  I wrote a VBScript that does the job. To get it to work you need to install the Pork2Sausage plugin of @donho and two tiny companion scripts.
                                  This is the VBScript, save it as CodeAlign.vbs:
                                  Option Explicit
                                  Const LVALUE = 0
                                  Const RVALUE = 1
                                  Dim strCode, arrCode, arrInLine, arrLValueTokens, strRValueTokens, intPrevMaxIdx
                                  Dim arrLine, arrMaxTokenLen, intLineIdx, intTokenIdx, intMaxRValueLen
                                  Dim intCnt, strLine, strToken, strOutput
                                  If Not WScript.StdIn.AtEndOfStream Then
                                    strCode = WScript.StdIn.ReadAll
                                    arrCode         = Split(strCode, vbNewLine)
                                    intMaxRValueLen = 0
                                    arrMaxTokenLen  = Array()
                                    arrLine         = Array()
                                    strOutput       = ""
                                    For intLineIdx = 0 To UBound(arrCode)
                                      If arrCode(intLineIdx) <> "" Then
                                        arrInLine       = Split(arrCode(intLineIdx), "=")
                                        arrLValueTokens = Split(Trim(arrInLine(0)), " ")
                                        strRValueTokens = Trim(arrInLine(1))
                                        If Len(strRValueTokens) > intMaxRValueLen Then
                                          intMaxRValueLen = Len(strRValueTokens)
                                        End If
                                        If UBound(arrLValueTokens) > UBound(arrMaxTokenLen) Then
                                          intPrevMaxIdx = UBound(arrMaxTokenLen)
                                          ReDim Preserve arrMaxTokenLen(UBound(arrLValueTokens))
                                          If intPrevMaxIdx < 0 Then
                                            arrMaxTokenLen(UBound(arrMaxTokenLen)) = 0
                                          Else
                                            arrMaxTokenLen(UBound(arrMaxTokenLen)) = arrMaxTokenLen(intPrevMaxIdx)
                                            For intCnt = intPrevMaxIdx To UBound(arrMaxTokenLen) - 1
                                              arrMaxTokenLen(intCnt) = 0
                                            Next
                                          End If
                                        End If
                                        For intCnt = 0 To UBound(arrLValueTokens)
                                          If intCnt < UBound(arrLValueTokens) Then
                                            If Len(arrLValueTokens(intCnt)) > arrMaxTokenLen(intCnt) Then
                                              arrMaxTokenLen(intCnt) = Len(arrLValueTokens(intCnt))
                                            End If
                                          Else
                                            If Len(arrLValueTokens(intCnt)) > arrMaxTokenLen(UBound(arrMaxTokenLen)) Then
                                              arrMaxTokenLen(UBound(arrMaxTokenLen)) = Len(arrLValueTokens(intCnt))
                                            End If
                                          End If
                                        Next
                                        ReDim Preserve arrLine(UBound(arrLine) + 1)
                                        arrLine(UBound(arrLine)) = Array(arrLValueTokens, strRValueTokens)
                                      End If
                                    Next
                                    For intLineIdx = 0 To UBound(arrLine)
                                      strLine  = ""
                                      strToken = arrLine(intLineIdx)(RVALUE)
                                      If IsNumeric(Left(strToken, Len(strToken) - 1)) Then
                                        strLine  = "= " & Right(String(intMaxRValueLen, " ") & strToken, intMaxRValueLen)
                                      Else
                                        strLine  = "= " & strToken
                                      End If
                                      For intTokenIdx = UBound(arrMaxTokenLen) To 0 Step -1
                                        If intTokenIdx = UBound(arrMaxTokenLen) Then
                                          strToken = arrLine(intLineIdx)(LVALUE)(UBound(arrLine(intLineIdx)(LVALUE)))
                                          strLine  = Left(strToken & String(arrMaxTokenLen(intTokenIdx), " "), arrMaxTokenLen(intTokenIdx)) & " " & strLine
                                        ElseIf UBound(arrLine(intLineIdx)(LVALUE)) > intTokenIdx Then
                                          strToken = arrLine(intLineIdx)(LVALUE)(intTokenIdx)
                                        Else
                                          strLine = String(arrMaxTokenLen(intTokenIdx), " ") & " " & strLine
                                        End If
                                      Next
                                      strOutput = strOutput & strLine & vbNewLine
                                    Next
                                    WScript.StdOut.Write strOutput
                                  End If
                                  At next you need a script that can retrieve the clipboard content and stream it to StdOut. It’s a one-liner in JavaScript, save it as pclip.js.
                                  WSH.Echo(WSH.CreateObject('htmlfile').parentWindow.clipboardData.getData('text'));
                                  At next you need a binding to PorkToSausage. It’s a Batch script, save it as CodeAlign.cmd.
                                  @echo off
                                  pushd "%~dp0"
                                  cscript /nologo /e:JScript pclip.js | cscript /nologo "CodeAlign.vbs"
                                  popd
                                  Put the files CodeAlign.vbs, pclip.js and CodeAlign.cmd together in one directory and move it to <Notepad++-installation-directory>\plugins\Pork2Sausage\CodeAlign.
                                  Finally you need to add the following to the config file of Pork2Sausage. The plugin provides the ability to load its own config file for editing.
                                  [CodeAlign]
                                  progPath=<Notepad++-installation-directory>\plugins\Pork2Sausage\CodeAlign\CodeAlign.cmd
                                  progCmd=CodeAlign
                                  workDir=<Notepad++-installation-directory>\plugins\Pork2Sausage\CodeAlign
                                  replaceSelection=true
                                  The Pork2Sausage plugin will add a menu entry named CodeAlign to its submenu of Plugins menu. You can assign a keyboard shortcut to this entry to simplify things.
                                  Please note that you have to configure the right path of your Notepad++ installation directory. If you already use Notepad++ v7.6 you should put the directory with the three scripts to the new plugin folder under %UserProfile%\AppData\Local\Notepad++\plugins\PorkToSausage. Of course you have to change the paths in the Pork2Sausage config file accordingly.
                                  To use the script select the code you want to align and copy it to the clipboard. Then press the keyboard shortcut you assigned to the script’s menu entry. It does its job and the result is automatically pasted to the selected block of lines in the Notepad++ window.
                                  If you (or another person) is able to write Python scripts, you/(s)he can port the VBScript code to Python and you can use the Python plugin to execute it. This way you wouldn’t need so much script files.
                                  • dinkumoilD
                                    dinkumoil
                                    @hoji-afzal
                                    Update: VBScript improved
                                    • Can handle and keep empty lines
                                    • Can handle and keep lines without equal sign
                                    • Code commented now
                                    Option Explicit
                                    Const LVALUE = 0
                                    Const RVALUE = 1
                                    Dim arrCode, arrInLine, arrLValueTokens, strRValueTokens, intPrevMaxIdx
                                    'Read input from StdIn
                                      'Split input into lines and store them in array
                                      arrCode = Split(WScript.StdIn.ReadAll, vbNewLine)
                                      'Delete empty trailing line
                                      If arrCode(UBound(arrCode)) = "" Then
                                        ReDim Preserve arrCode(UBound(arrCode) - 1)
                                      End If
                                      arrLine         = Array()
                                      intMaxRValueLen = 0
                                      strOutput       = ""
                                      'Process all lines
                                        'If current line is empty create empty variables for LValue and RValue
                                        If arrCode(intLineIdx) = "" Then
                                          arrLValueTokens = Array("")
                                          strRValueTokens = ""
                                        Else
                                          'Split line in LValue and RValue, delete preceding and trailing space
                                          'characters and split LValue in tokens
                                          'RValue could be empty
                                          If UBound(arrInLine) > 0 Then
                                          Else
                                          End IF
                                          'Remember maximum length of all RValues
                                          End If
                                          'Build array with a table containing the maximum length of all tokens
                                          'in the same column.
                                          'If the number of tokens of the current LValue is greater than the number
                                          'of columns of the table it has to be enlarged.
                                            'Remember index of currently last table cell and enlarge it
                                            'Shift the value of the last table cell before enlargement
                                            'to the last cell after enlargement
                                              'If the table had been empty before enlargement set the new element to 0
                                            Else
                                              'Set the currently last cell of the table to the value
                                              'of the previously last cell
                                              'Set the newly added cells to 0
                                              Next
                                            End If
                                          End If
                                          'If the current line contains longer tokens in any column than the lines
                                          'processed before remember the greater length
                                            'If we do not inspect the last table cell compare the same columns of
                                            'the LValue tokens and the maximum token length table
                                              End If
                                            'I we inspect the last LValue token alway compare it with the last cell
                                            'of the maximum token length table
                                            Else
                                              End If
                                            End If
                                          Next
                                        End If
                                        'Enlarge ouput array and store array with LValue tokens and RValue string
                                      Next
                                      'Iterate over output array of loop above and build up an output line from
                                      'LValue tokens and the RValue. The output line gets assembled from right to left.
                                        strLine  = ""
                                        'Get RValue of current line
                                        'Add equal sign and RValue only to the output line if RValue is not empty
                                        If strToken <> "" Then
                                          'If the RValue is a number right align it otherwise take it as is
                                          Else
                                          End If
                                        End If
                                        'Iterate over the maximum token length table starting with last column
                                          'When processing the last column, take the last LValue token of the
                                          'current line, right-pad it with space characters to bring it to the
                                          'lenght of the longest token in this column and prepend it to output line
                                          'When processing a column where the current LValue has a token, right-pad
                                          'it with space characters to bring it to the lenght of the longest token
                                          'in this column and prepend it to output line
                                          'When processing a column where the current LValue has no token, pad with
                                          'space characters to bring it to the lenght of the longest token in this
                                          'column and prepend it to output line
                                          Else
                                          End If
                                        Next
                                        'Avoid appending of lines which contain solely space characters
                                        If Trim(strLine) = "" Then strLine = Trim(strLine)
                                        'Append output line to output string
                                        'Dont terminate last line with EOL because it's added automatically
                                        If intLineIdx < UBound(arrLine) Then
                                          strOutput = strOutput & vbNewLine
                                        End If
                                      Next
                                      'Stream output string to StdOut
                                    End If
                                    • hoji afzalH
                                      hoji afzal
                                      Oh man, thanks so much guys for your input!
                                      I will try these once my manager stops with his “so how much progress did you make?” :)
                                      I am a fanatic aligner, just bordering having a disease. But usually don’t have time to go that “extreme”. And by extreme I am sure you refer to my right aligning the whole numbers hahaha
                                      Thanks.
                                      • dinkumoilD
                                        dinkumoil
                                        Oh yeah, the managers…
                                        Since you seem interested I have another update of the VBScript for you:
                                        • Improved handling of aligning lines containing no assignment operator
                                        • Delimiter and assignment operator configurable by constant in script
                                        • Keeps indentation
                                        • Improved detection of empty lines
                                        • Avoiding superfluous output lines and output lines filled solely with space characters
                                        Option Explicit
                                        Const LVALUE   = 0
                                        Const RVALUE   = 1
                                        Const DelimChr = " "
                                        Const AssignOp = "="
                                          End If
                                          arrLine         = Array()
                                          intMaxRValueLen = 0
                                          strOutput       = ""
                                          'Process all lines
                                            If Trim(arrCode(intLineIdx)) = "" Then
                                            Else
                                              'Split line in LValue and RValue, keep indentation of LValue but delete
                                              'preceding and trailing space characters of RValue and split LValue in
                                              'tokens
                                              arrInLine       = Split(arrCode(intLineIdx), AssignOp)
                                              arrLValueTokens = Split(RTrim(arrInLine(0)), DelimChr)
                                              'There could be no RValue
                                              Else
                                              End IF
                                              End If
                                              'Build a maximum token length table containing the maximum length of all
                                              'LValue tokens in the same column
                                                'Remember index of currently last table cell and enlarge table
                                                If intPrevMaxIdx < 0 Or strRValueTokens = "" Then
                                                  'If the table had been empty before enlargement set new cell to 0
                                                Else
                                                  'Set the currently last cell of the table to the value of the
                                                  'previously last cell
                                                  Next
                                                End If
                                              End If
                                              'processed before, remember the greater length
                                                'If we do not inspect the last table cell, compare the same columns of
                                                If intCnt < UBound(arrLValueTokens) Or strRValueTokens = "" Then
                                                  End If
                                                'I we inspect the last LValue token, always compare it with the last cell
                                                Else
                                                  End If
                                                End If
                                              Next
                                            End If
                                          Next
                                            strLine  = ""
                                            'Add assignment operator and RValue to output line only if RValue is not empty
                                                strLine = AssignOp & " " & Right(String(intMaxRValueLen, " ") & strToken, intMaxRValueLen)
                                              Else
                                                strLine = AssignOp & " " & strToken
                                              End If
                                            End If
                                              If intTokenIdx = UBound(arrMaxTokenLen) And arrLine(intLineIdx)(RVALUE) <> "" Then
                                                strLine  = Left(strToken & String(arrMaxTokenLen(intTokenIdx), " "), arrMaxTokenLen(intTokenIdx)) & DelimChr & strLine
                                              ElseIf (UBound(arrLine(intLineIdx)(LVALUE)) > intTokenIdx) Or _
                                                     (UBound(arrLine(intLineIdx)(LVALUE)) = intTokenIdx And arrLine(intLineIdx)(RVALUE) = "") Then
                                                If intTokenIdx = UBound(arrMaxTokenLen) And arrLine(intLineIdx)(RVALUE) = "" Then
                                                Else
                                                End If
                                              Else
                                                Else
                                                  strLine = String(arrMaxTokenLen(intTokenIdx), " ") & DelimChr & strLine
                                                End If
                                              End If
                                            Next
                                            If Trim(strLine) = "" Then strLine = ""
                                            'Dont terminate last line with EOL because it is added automatically
                                            End If
                                          Next
                                        End If
                                        Unfortunately the Pork2Sausage plugin currently has a bug, it streams at maximum 1024 bytes/characters back to Notepad++. I’ve already created a pull request with a fix, let’s see if and when it will be published.
                                        • hoji afzalH
                                          hoji afzal
                                          Thanks for the code. But I’m sorry I still haven’t had a chance to try it. Plus, I am not very experienced with scripts.
                                          However, I did try TextFX and find its tool useful. I have set up a shortcut for it which I have been using. It’s TextFX > TextFX Edit > E: Line up multiple lines by (Clipboard Character). Unfortunately it doesn’t accept either space (perhaps the most useful character) or a pattern of characters. But still it’s Okay.
                                          Having said that, that menu is nowhere near as powerful or useful as a context menu to select a block and set it either right or left justified.
                                          Hoji
                                            Hello @hoji-afzal @peterjones, @dinkumoil, @scott-sumner, @chcg and All,
                                            I’ve found out a solution to line up with the space character :-)) Nevertheless, it’s just a work-around which could be rather tedious, if you want to line up a lot of small blocks of text :-(( Just have a try !
                                            It does not imply any script, just the TextFX plugin of course, and the native N++ Search/Replacement feature ;-))
                                            Here are, below, the different steps to follow :
                                            • First, anywhere in a file, on an empty location, hold down the ALT key and type, successively, on keys 0, 3 and 1, of the numeric keypad, then release the ALT key
                                            => A control character US, with code-point = \x1F, should be displayed, in reverse video !
                                            • Copy this single character in the clipboard
                                            • Select all the ( not aligned ) text of your previous example
                                            • Now, open the Replace dialog ( Ctrl + H )
                                            • SEARCH \x20+
                                            • REPLACE \x1f
                                            • Check the In selection option, ( on the left of the Replace All button ) IMPORTANT
                                            => At once, all range of consecutive space characters, in the selection, are replaced with the control character US
                                            • Then, click on the TextFX menu, leaving the Replace dialog in the background
                                            • Select the option TextFX > TextFX Edit > Line up multiple lines by (Clipboard Character)
                                            => Now, most of the US characters should be aligned !
                                            • Click back on the Replace dialog ( Note that your text is still selected )
                                            • SEARCH \x1f
                                            • REPLACE \x20
                                            • Keep the same options as above
                                            => You should get the result, below :
                                            At first sight, we remark that some words are quite aligned, but not exactly in the way you would !:-(( The problem comes from the expressions Const int and Const double that you consider as single entities whereas the TextFX plugin considers, logically, that there are two consecutive words, separated with a space char !
                                            So, regarding your very simple block of code, I would say that the rule is : when a space character, is located after the word const, in lower-case, it should not be replaced with the US control char
                                            Thus, if you re-execute all the previous steps, replacing the first search regex \x20+ with the regex (?-i)(?<!\bconst)\x20+, you should be left with the expected text, below :
                                            Nice, isn’t it ? Note you still have to align the numbers, at the end of the lines !
                                            REMEMBER : When using the line up feature, the TextFX plugin does not consider any ,, = or clipboard character which are between two double quotes "........" nor between two simple quotes '........' !
                                            If you are interested to go further on, @hoji-afzal, just tell me all the multi-words expressions which need to be considered as a single word and I’ll try to get the appropriate regex, which preserves space characters, in these expressions :-))
                                            hoji afzalH 1 Reply Last reply Reply Quote 3
