    Is there a way to hide commands?
    21 Posts 5 Posters 6.4k Views
    • Volkan ÇolakV
      Volkan Çolak
      Yes sadly i have >. Thanks for everything who trying to help, let me show you the “exactly” what i want. But it translates all codes as well. If i cannot find, i will try to “re-translate” tags to their original values but sadly i have many tags.
      http://i.hizliresim.com/dBpddD.png
        Hello, @volkan-çolak,
        I saw, one minute ago, that you’re on-line on our site ! So, just be patient one hour, about, as I found out a solution to your problem and I’m preparing a post to give you the method ;-))
        See you later,
          Hello, @volkan-çolak, @peterjones, @scott-sumner and All,
          Aaaaah ! Yes, it took me some time to completely figure out your tricky problem, but I finally found out a solution ;-)) This method is long enough and I advice you to read this post, completely, before going ahead with the different steps to perform !
          This method consists, principally, in :
          • Some copy/paste operations, of course
          • An N++ sort operation
          • Several searches/replacements, which will use the regular expression search mode
          In this respect, for each S/R, simply follow these steps :
          • Open the N++ Replace dialog ( Ctrl + H )
          • Type in ( or copy/paste ) the SEARCH  regex in the Find what: zone
          • Type in ( or copy/paste ) the REPLACE  regex in the Replace with: zone
          • Set the Wrap around option
          • Click on the Replace All button ( Do not use the Replace button ! )
          Well, now, let’s go !
          • From your picture, I simply created a similar code, while trying to get a correct sequence, as below, which represents a short part of your data :
          <Row ss:StyleID="s3">
            <Cell>
              <Data ss:Type="String">Retreat</Data>
            </Cell>
            <Cell>
              <Data ss:Type="String">Tears</Data>
            </Cell>
            <Cell>
              <Data ss:Type="String">Dialog.Option.101.Text</Data>
            </Cell>
            <Cell>
              <Data ss:Type="String">Scenario Data</Data>
            </Cell>
          </Row>
            <Cell>
              <Data ss:Type="String">The orc shamans want to join you.</Data>
            </Cell>
            <Cell>
            </Cell>
            <Cell>
              <Data ss:Type="String">Dialog.Option.358.OptionText</Data>
            </Cell>
            <Cell>
            </Cell>
          </Row>
            <Cell>
              <Data ss:Type="String">Accept</Data>
            </Cell>
            <Cell>
            </Cell>
            <Cell>
            </Cell>
            <Cell>
            </Cell>
          </Row>
          • First, I strongly advice you to do a copy of your original data
          Remark : We, all, should act as Mother Nature does : it never uses ADN genetic code. It always replicates it, first, as an ARN sequence, which, then, is used for any bio-chemical action ! Believe me, it’s been working… … … for 3,7 billion years !
          • So, open a COPY of your original file, in Notepad++
          • Now, using the first S/R, below, it should extract all the white zones of text, that you spoke of, in your picture
          SEARCH (?s)\s*<.+?"String">\s*|<.+
          REPLACE \r\n ( or \n if you work on Unix files )
          You should obtain the different lines, below :
          Retreat
          Tears
          Scenario Data
          Scenario Data
          Accept
          Accept
          Scenario Data
          • Choose, now, the menu command Edit > Line Operations > Sort Lines Lexicographically Ascending. your text becomes sorted, as below :
          Accept
          Accept
          Retreat
          Scenario Data
          Scenario Data
          Scenario Data
          Tears
          • Perform, then, the following S/R, in order to delete all duplicate lines of that list :
          SEARCH ^(.*\R)\1+
          REPLACE \1
          you should obtain this shortened list :
          Accept
          Retreat
          Scenario Data
          Tears
          • Now, paste the different lines of this American-English text, on an on-line translator. You said that you generally, use the Google one, but, personally, I prefer the translator, below, based on neuronal networks, which is really very efficient ::-)
          https://www.deepl.com/translator
          Well. So, let’s imagine that we would like to translate in French, using deepl.com site. We get the French list, below, that we paste, back, in N++ :
          Accepter
          Option.de.dialogue.101.Texte
          Option.Dialog.Option.358.OptionText
          Se retirer
          Données de scénario
          Larmes
          Les chamans orcs veulent se joindre à vous.
          I simply changed the French nom "Retraite " with the French verb "Se retirer ", which is better, given the context !
          • Now, we’re about to build the correct file, in order to run our last S/R ! So, in a new N++ tab :
            • Insert your original data, first :
            • Add a new line, made up several equal signs as, for instance ==================
            • Append all the English sentences, that we extracted, at first step
            • Add, again, a line ==================
            • Finally, add the French sentences, obtained from the on-line translator
          This text should be, as below :
            <Cell>
            </Cell>
            <Cell>
            </Cell>
            <Cell>
            </Cell>
            <Cell>
            </Cell>
          </Row>
            <Cell>
            </Cell>
            <Cell>
            </Cell>
            <Cell>
            </Cell>
            <Cell>
            </Cell>
          </Row>
            <Cell>
            </Cell>
            <Cell>
            </Cell>
            <Cell>
            </Cell>
            <Cell>
            </Cell>
          </Row>
          Accept
          Retreat
          Scenario Data
          Tears
          Accepter
          Se Retirer
          Données de scénario
          Larmes
          Almost done !
          • We just have to run the last regex S/R, below, which changes all American/English sentences, in your code, with the matched French translation of these sentences !
          SEARCH (?-s)(?<="String">)(.+?)(?=</Data>(?s).+^=+.*?\R\1\R(?-s)(?:.+\R){7}(.+))|(?s)^=+.+
          REPLACE \2
          IMPORTANT : The number seven, in the syntax {7}, is the total number of lines translated. Thus, le number 7, in our example
          After replacement, you’re left with the expected text, containing translated “white” sentences, only ;-))
            <Cell>
              <Data ss:Type="String">Se Retirer</Data>
            </Cell>
            <Cell>
              <Data ss:Type="String">Larmes</Data>
            </Cell>
            <Cell>
              <Data ss:Type="String">Option.de.dialogue.101.Texte</Data>
            </Cell>
            <Cell>
              <Data ss:Type="String">Données de scénario</Data>
            </Cell>
          </Row>
            <Cell>
              <Data ss:Type="String">Les chamans orcs veulent se joindre à vous.</Data>
            </Cell>
            <Cell>
            </Cell>
            <Cell>
              <Data ss:Type="String">Option.Dialog.Option.358.OptionText</Data>
            </Cell>
            <Cell>
            </Cell>
          </Row>
            <Cell>
              <Data ss:Type="String">Accepter</Data>
            </Cell>
            <Cell>
            </Cell>
            <Cell>
            </Cell>
            <Cell>
            </Cell>
          </Row>
          Et voilà !
          Next time, I’ll give you some explanations on the regexes used, if you want to !
          Volkan ÇolakV 1 Reply Last reply Reply Quote 4
          • Jim DaileyJ
            Jim Dailey
            @guy038
            Incroyable ! Nous avons besoin d’un bouton de vote à la hausse qui ajoute 10 votes !
              Assuming that says what I think it says (I saw “button vote … 10 votes”), I second that motion. Actually, I square that motion; I would give +100 for that answser. :-)
                Hi, @jim-dailey and @peterJones,
                Thank you, guys, but I believe that we should remain modest ! Anyway, you, both, provide very detailed posts on various topics, too ! So, I could return the compliment to you !
                We, all, just do our best to help anyone, when we think of a right solution ;-))
                • Jim DaileyJ
                  Jim Dailey
                  @guy038
                  guy038> Thank you, guys, but I believe that we should remain modest !
                  Not to invite or start a political war, but I have to say, you’ll never be President of the U.S. with that kind of attitude!
                  Volkan ÇolakV 1 Reply Last reply Reply Quote 1
                  • Volkan ÇolakV
                    Volkan Çolak @guy038
                    @guy038 Omg i haven’t read it yet but even if you succeed or not, you deserve respect. Before i begin (tonight i will available) i truly wanted to thank you so much!
                    • Volkan ÇolakV
                      Volkan Çolak @Jim Dailey
                      @Jim-Dailey Ehm. First of all thank you but it seems my knowledge + my english is unsufficient for this :( i felt guilty but i wasn’t expected it to be a difficult like this. I was tought it could be the plugin that can hides html codes :(
                      • Jim DaileyJ
                        Jim Dailey
                        @Volkan-Çolak
                        I think we are having language difficulties.
                        I did not help answer your question at all, so I’m not sure why you would thank me. But, you are welcome!
                        I just tried to praise @guy038 for his amazing answer (using the site he mentioned, https://www.deepl.com/translator, so that I could post in French, which I assume is Guy’s native language).
                        Then made a poor joke about his reply to my French posting.
                        I think you will find Guy’s post very useful. Best of luck!
                          Hi, @jim-dailey,
                          To be honest, the Google translation, of the American/English text, of my previous post, in French, wasn’t so bad, either !
                          But I suppose that neuronal networks are, definitively, a + for translation matters and I was, also, a bit impressed by the press comments about DeepL translator performances ;-))
