    deplace a block to an other place
    27 Posts 7 Posters 18.4k Views
    • Pouemes44P
      Pouemes44
      hello
      i have a question
      i am trying to understand how what has given to me guy works
      (?s)(<noscript class.+?</noscript>\R)(.+?style=“display:none;”></div>\R)
      if i try to get an other sequence between a a tag by example… i got nothing! what is wrong?
      (?s)(<a href.+?</a>\R)
      with an img tag it doesnt take the first “> why? :-) thanks
      (?s)(<img class.+?”>\R)
        Claudia Frank @Pouemes44
        @kat75
        without having the data we cannot say for sure what went wrong.
        So, in theory, the hyperlink regex would match everyhting within the tag if
        closing tags is directly followed by an eol char (no space)
        and the image regex would match starting with <img class followed by
        anything until ”> appears, followed directly by an eol char.
        • Pouemes44P
          Pouemes44
          at the end it must be a eol character, ok i understand now
          • Pouemes44P
            Pouemes44
            i would to say thanks to all, i have well succeed to move my block and begin to understand a bit notepad++
            is there a way to send private messages on notepad community, i dont find how
            • Pouemes44P
              Pouemes44
              Hello
              do you think that its possible to move a block not to the bottom but to the top?
              i dont succeed
              i mean that in this example, how to move <img etc… and …style=“display:none;”></div> just before <noscript class"text" lang=“example”>
              1.html
              line1
              line2
              line3
              line4
              </noscript>
              some text…
              etc…
              etc
              <img… and …style=“display:none;”></div>
              2.html
              <noscript class"text" lang=“otherexample”>
              otherline1
              otherline2
              otherline3
              otherline4
              </noscript>
              othersome text…
              etc…
              etc etc
              <img… other and …style=“display:none;”></div>
                Hello, @pouemes44, and All,
                Here is, below, the general method in order to switch two consecutive blocks of text, separated, or not, by some stuff text
                So let’s start with the example text, below :
                bla
                bla
                bla
                Block 1
                of
                some
                text
                End block
                bla bla
                bla bla
                bla bla
                bla bla
                Block 2
                with some
                other text
                End block
                bla bla bla
                bla bla bla
                bla bla bla
                To correctly determine the limits of your block of text, whatever it is, you, necessarily, need to know :
                • The location of the beginning of your block. In our example, I suppose that it’s the regex ^Block \d+
                • The location of the end of your block. In our case, I suppose it’s the string End block
                IMPORTANT : In our example, the second block has the same limits as Block 1, but it could, perfectly, have some other limit definitions !
                So, from the above definitions, we can build the regex S/R, below :
                SEARCH (?s)(^Block \d+.+?End block)(.*?)(^Block \d+.+?End block)
                REPLACE \3\2\1
                Notes :
                • The leading (?s) modifier means that the special dot character represents, absolutely, any single character. Now :
                • The first part, (^Block \d+.+?End block, represents a complete individual block of text, stored as group 1
                • The third part, (^Block \d+.+?End block), stands, again, for an other complete block of text, stored as group 3
                • The middle part, (.*?), is the shortest range, even empty, of any character, between these two consecutive blocks of text
                • In replacement, we just switch the group 1 and 3, with group 2 standing as a pivot
                And, after a click on the Replace All button, you should get the expected text , below :
                bla
                bla
                bla
                Block 2
                with some
                other text
                End block
                bla bla
                bla bla
                bla bla
                bla bla
                Block 1
                of
                some
                text
                End block
                bla bla bla
                bla bla bla
                bla bla bla
                Just note that, if the two blocks are strictly consecutive, without the bla bla lines, as below :
                bla
                bla
                bla
                Block 1
                of
                some
                text
                End block
                Block 2
                with some
                other text
                End block
                bla bla bla
                bla bla bla
                bla bla bla
                We still get the correct modified text :
                bla
                bla
                bla
                Block 2
                with some
                other text
                End block
                Block 1
                of
                some
                text
                End block
                bla bla bla
                bla bla bla
                bla bla bla
                Now, Pouemes44, let’s apply this general method to your particular problem :
                The general template, of your first block, is :
                <noscript......
                </noscript>
                The general template, of your second block, is :
                <img.........
                style="display:none;"></div>
                Therefore, the corresponding regex S/R, in your case, is, obviously :
                SEARCH (?s)(^<noscript.+?</noscript>)(.*?)(^<img.+?style="display:none;"></div>)
                REPLACE \3\2\1
                So, considering your example, below :
                1.html
                <noscript class"text" lang="example">
                line1
                line2
                line3
                line4
                </noscript>
                some text…
                etc…
                etc
                <img… and …style="display:none;"></div>
                2.html
                <noscript class"text" lang="otherexample">
                otherline1
                otherline2
                otherline3
                otherline4
                </noscript>
                othersome text…
                etc…
                etc etc
                <img… other and …style="display:none;"></div>
                After performing the above S/R, you’ll get the modified text, as expected to :
                1.html
                some text…
                etc…
                etc
                line1
                line2
                line3
                line4
                </noscript>
                2.html
                othersome text…
                etc…
                etc etc
                otherline1
                otherline2
                otherline3
                otherline4
                </noscript>
                Et voilà !!
                P.S. : Beware that, on our NodeBB site, text, containing starting and ending usual simple and double quotes, are changed into their Unicode equivalents, below :
                • Starting simple quote ‘, of Unicode code-point \x{2018}, instead of the single quote sign ' ( x{0027 )
                • Ending simple quote ’, of Unicode code-point \x{2019}, instead of the single quote sign ' ( x{0027 )
                • Starting double quote “, of Unicode code-point \x{201C}, instead of the double quote sign " ( x{0022 )
                • Ending double quote ”, of Unicode code-point \x{201D}, instead of the double quote sign " ( x{0022 )
                Notes :
                • For ANSI encoded texts, to avoid the nasty message Find: Invalid regular expression, the **correct regex syntaxes are, respectively, \x91, \x92, \x93 and \x94
                BTW :
                • Remember that the \x{####} regex syntax can be used :
                  • For search of a true ASCII character, between \x{0000} and \x{007F}, in ANSI encoded files
                  • For search of any Unicode character, between \x{0000} and \x{FFFF}, in UNICODE encoded files
                • Remember that the \x{##} regex syntax can be used :
                  • For search of a true ASCII character, between \x{00} and \x{7F}, in ANSI encoded files
                  • For search of any Unicode character, between \x{00} and \x{FF}, in UNICODE encoded files
                • To end with, remember that the \x## regex syntax can be used :
                  • For search of any Unicode character, between \x00 and \xFF, either, in UNICODE or ANSI encoded files
                • Pouemes44P
                  Pouemes44
                  a great thanks guy
                  that was this part (.*?) i missed
                  • Pouemes44P
                    Pouemes44
                    i have an other question
                    if i search (?s)(<h1.+?</h1>\R) i got a result in my file
                    but if i search (?s)(<a.+?</a>\R) to get <a href=“mypage.htm” title=page">page</a> i got nothing why? what is wrong?
                      Hello, @pouemes44,
                      • In the regex (?s)(^Block \d+.+?End block)(.*?)(^Block \d+.+?End block), of my previous post, the part (.*?) represents the shortest range of characters, even empty, stored as group 2, between the two consecutive blocks of text, that are to be swapped !
                      Now, if we consider the HTML example text, below :
                      <td height="15">
                          <font size="2" color="black" face="arial, verdana"><b>Lire un message / dossier : Reçus</b></font>
                      </td>
                      <td height="15">
                      </td>
                      Beware about the two different behaviours :
                      • The regex (?s)<td.+</td> looks for the largest range of characters .+, between the strings <td and </td> => It matches all the text, at once
                      • The regex (?s)<td.+?</td> looks for the shortest range of characters .+?, between the strings <td and </td> => it matches, successively, each block <td…</td>
                      Now, regarding your HTML text :
                      I suppose that you do NOT get a match, using the regex (?s)(<a.+?</a>\R), because, probably, it’s the last line of your current file, which is NOT followed by any End of line character !
                      Indeed, in that case, the ending part \R cannot match anything. So the overall match fails :-((
                      Two solutions :
                      • Use the regex (?s)(<a.+?</a>\R?). With that syntax, the \R part is optional
                      • Add a line break to this last line !
                      For a better visualization of the End of line characters, just click on the ¶ icone
                      • Pouemes44P
                        Pouemes44
                        Hello Guy
                        i just see your answer
                        a great thanks, yes work with (?s)(<a.+?</a>\R?)
                        a real thanks for all your explanations, i already succeed to do wonderful things with them.
                          Hi, All,
                          I’m back for additional information, about lazy, greedy and possessive quantifiers. it’s fundamental to, correctly, understand the differences, between these 3 types of quantifiers !
                          So, let’s consider the simple text 12345ABCDE, in a new tab
                          How the regex engine interprets, for instance, the regex \w{1,10}[A-Z]{5}, with the greedy quantifier {1,10} ?. Well :
                          • It, first, tries to match the LONGEST range of \w => 10 Word characters. But, the part [A-Z]{5} CANNOT match anything
                          • Then, it backtracks and tries the first 9 Words characters. Again, the part [A-Z]{5} does NOT match the E letter
                          • Then, it backtracks and tries the first 8 Words characters. Again, the part [A-Z]{5} does NOT match the DE letters
                          • Then, it backtracks and tries the first 7 Words characters. Again, the part [A-Z]{5} does NOT match the CDE letters
                          • Then, it backtracks and tries the first 6 Words characters. Again, the part [A-Z]{5} does NOT match the BCDE letters
                          • Then, it backtracks and tries the first 5 Words characters. This time, the part [A-Z]{5} DOES match the ABCDE letters
                          => After the backtracking phase, all the text is matched and selected !
                          Now, how the regex engine interprets the regex \w{1,10}?[A-Z]{5}, with the lazy quantifier {1,10}? ?
                          • It, first, tries to match the SHORTEST range of \w => 1 Word character. But, the part [A-Z]{5} CANNOT match the 2345ABCDE string
                          • Then, it backtracks and tries the first 2 Words characters. Again, the part [A-Z]{5} does NOT match the 345ABCDE string
                          • Then, it backtracks and tries the first 3 Words characters. Again, the part [A-Z]{5} does NOT match the 45ABCDE string
                          • Then, it backtracks and tries the first 4 Words characters. Again, the part [A-Z]{5} does NOT match the 5ABCDE string
                          Note : Instead of the English werb backtrack, the verb fortrack would be more adapted ! Sorry, English isn’t my mother tongue !
                          Finally, how the regex engine interprets the regex \w{1,10}+[A-Z]{5}, with the possessive quantifier {1,10}+ ?
                          • Now, the normal process would be to backtrack. But this action is forbidden, due to the possessive quantifier ! In other words, once a match has been found, for the first part \w{1,10}+, the following parts of the regex must match the remaining of the text. But, as the first regex part have consumed all the text, the part [A-Z]{5} will NEVER match anything !
                            So, the overall match fails and you get the normal message Find: Can’t find the text “\w{1,10}+[A-Z]{5}”
                          Using, again, the same example 12345ABCDE, in a new tab, it’s easy to verify that :
                          • The regex \w{1,10} matches the longest Word characters range => The whole string 12345ABCDE is matched
                          • The regex \w{1,10}? matches the shortest Word characters range => The 1 Word character is matched, then the 2 digit and so on…
                          • The regex \w{1,10}+ matches the longest Word characters range => The whole string 12345ABCDE is matched, too !
                          So, to sum up, here is, below, a list of all the quantifiers :
                              GREEDY     quantifiers   :    *  ( = {0,} )       + ( = {1,} )      ?  ( = {0,1} )      {n}        {n,}        {m,n}
                              LAZY       quantifiers   :    *? ( = {0,}? )     +? ( = {1,}? )     ?? ( = {0,1}? )     {n}?       {n,}?       {m,n}?
                              POSSESSIVE quantifiers   :    *+ ( = {0,}+ )     ++ ( = {1,}+ )     ?+ ( = {0,1}+ )     {n}+       {n,}+       {m,n}+
                          Remark : The two {n}? and {n}+ syntaxes, although correct, are useless, as the syntax {n} could be qualified as an EXACT quantifier !
