    Python / Lua Script: Detect if a modifier is pressed when running a script
    60 Posts 5 Posters 74.5k Views 4 Watching
    • YaronY Offline
      Yaron
      Hello,
      How can I detect if a modifier was pressed when the user executed a script?
      Detecting a right-click would be better (i.e. execute the script on both left/right-click and detect the button).
      BTW, there seems to be a bug in Python Script: if you press Ctrl when running a script, the “File not found. Create it?” message is displayed.
      It works fine in @dail’s Lua Script.
      Thank you.
      Best regards.
      • Claudia FrankC Offline
        Claudia Frank @Yaron
        Hi @Yaron,
        not 100% sure what you want to achieve but my regex tester script
        may give you an idea what needs to be done to capture key presses. Check Hook class.
        About the bug, where is the script stored?
        • YaronY Offline
          Yaron
          Hello again,
          Correction: Ctrl+left-click opens the file instead of running the script.
          If the file name is Hebrew, it can not be found and hence the message.
          • YaronY Offline
            Yaron
            Hello Claudia,
            Thanks for replying. I do appreciate it.
            I’d like to have a slightly different behavior in case Alt is pressed.
            I’ll have a look in your script.
            And the bug is actually a problem in handling the Hebrew file name.
            Best regards.
            • YaronY Offline
              Yaron
              Hello Claudia,
              After a quick look in your script:
              Is using ctypes the only way to detect if a modifier was pressed?
              Can’t it be achieved with some keys module?
              And allow me to clarify:
              I want to know if a modifier was pressed when starting the script. NOT when it’s already running.
              Thanks again.
                Claudia Frank
                Hi Yaron,
                no, unfortunately neither scintilla nor notepad provide a keyup/keydown event which could be
                consumed.
                The only way, I know, is using ctypes and I think python modules which would offer this would also
                call win api to get the events.
                So you need to have the keyboard logger registered within startup.py ;-)
                • YaronY Offline
                  Yaron
                  Hello Claudia,
                  Thank you for the detailed explanation. I appreciate it.
                  I haven’t thoroughly learned the script yet.
                  If I have a bool altPressed in startup.py, I’d need to set it to false on Alt-UP only after some timeout. Is that correct?
                  Claudia FrankC 2 Replies Last reply Reply Quote 0
                    Yaron,
                    in your case, if I understand it correctly, I would use
                        if msg in [WM_KEYDOWN, WM_SYSKEYDOWN]:
                    to set the boolean true and
                        elif msg in [WM_KEYUP,WM_SYSKEYUP]:
                    to set it to false
                    and you need to handle the cases when alt together with other modifiers is pressed.
                      @Yaron
                      sorry, I missed this one.
                      So you do have defined a button in the toolbar, correct?
                      And when clicking with left mouse = normal run but when clicking with right mouse then advanced run?
                      • YaronY Offline
                        Yaron
                        Or setting it to false only in the altDependentScript.
                        I’ll think about it.
                        You’ve been very helpful as always. :)
                        Thank you very much.
                          Yaron, in case you want to get the mouse clicks see here.
                          Cheers and good night
                          • YaronY Offline
                            Yaron
                            Hello again Claudia,
                            That’s correct.
                            Getting the specific command/button position would be too much. :)
                            Thanks again. Highly appreciated.
                            Good night.
                            • dailD Offline
                              dail
                              As far as LuaScript goes you’d probably be alot more limited as you have to use what Scintilla/Notepad++ provides which you can catch double clicks and get the modifier keys but don’t think there’s a way to distinguish between left or right click. You could also register the same function with more than one keyboard shortcut, such as “F5”, “Ctrl+F5”, “Alt+F5”, etc…but this is not ideal.
                              Python gives more possibilities as far as interacting with the OS so this is probably your better option depending what you need exactly.
                              • YaronY Offline
                                Yaron
                                Hello @dail,
                                Thank you for the additional info. I appreciate it.
                                If I understand it correctly, SCN_DOUBLECLICK is only relevant to the editor.
                                Double-click could have been useful, but I need it for a command or a toolbar button.
                                And thanks again for the great Lua Script plugin.
                                BTW, Ctrl+left-click to open the file instead of running the script could be a nice addition to Lua Script.
                                What do you think?
                                • dailD Offline
                                  dail
                                  Oh! Now I see what you are doing. In this case PythonScript is your best option.
                                  Honestly I don’t even know if would be possible. Since individual functions are registered instead of files, there is nothing that associates where a function is defined.
                                  • YaronY Offline
                                    Yaron
                                    Hello @dail,
                                    A simple example for what I meant:
                                    A script TypeLetter types a letter in the editor. Using Customize Toolbar, I’ve assigned a toolbar button to the script.
                                    I want it to normally type A but if Alt is down when pressing the toolbar button type B.
                                    Claudia’s suggestion is a good option, but I think I’d have to use some timeout.
                                    Using another script Toggle TypeLetter Mode is another option which should work well in Lua Script too.
                                    Since individual functions are registered instead of files…
                                    I didn’t think about that. :)
                                    Thanks again.
                                      Hello Yaron
                                      a quick script about what I meant with mouse click capture.
                                      In one script you intercept the window proc (needs to be called first, startup.py might be good choice)
                                      from ctypes import windll, byref, wintypes, WINFUNCTYPE, Structure, sizeof
                                      WndProcType = WINFUNCTYPE(wintypes.LONG,
        wintypes.HWND,
        wintypes.UINT,
        wintypes.WPARAM,
        wintypes.LPARAM)
                                      GWL_WNDPROC = -4
                                      WNDENUMPROC = WINFUNCTYPE(wintypes.BOOL,
        wintypes.HWND,
        wintypes.LPARAM)
                                      _g = globals()
                                      CAPTURE_MOUSE_CLICK = _g.get('CAPTURE_MOUSE_CLICK', False)
                                      OLD_WND_PROC = _g.get('OLD_WND_PROC', None)
                                      LEFT_MOUSE_CLICK_MOD = False
                                      class Hook():
                                          def EnumCallback(self, hwnd, lparam):
                                              curr_class = (wintypes.WCHAR * 256)()
                                              windll.user32.GetClassNameW(hwnd, curr_class, 256)
                                              if curr_class.value.lower() == 'toolbarwindow32':
                                                  self.toolbar_handle = hwnd
                                                  return False
                                              return True
                                          def __init__(self):
                                              self.toolbar_handle = None
                                              parent = windll.user32.FindWindowA('Notepad++',None)
                                              windll.user32.EnumChildWindows(parent, WNDENUMPROC(self.EnumCallback), 0)
                                              self.oldWndProc = None
                                              self.SHIFT_PRESSED = False
                                              self.CTRL_PRESSED = False
                                              self.ALT_PRESSED = False
                                          def register(self):
                                              if self.toolbar_handle:
                                                  self.new_wnd_proc = WndProcType(self.sciWndProc)
                                                  windll.kernel32.SetLastError(0)
                                                  self.oldWndProc = windll.user32.SetWindowLongA(self.toolbar_handle, GWL_WNDPROC, self.new_wnd_proc)
                                                  if self.oldWndProc:
                                                      global OLD_WND_PROC
                                                      OLD_WND_PROC = self.oldWndProc
                                                  else:
                                                      _err = 'GetLastError:{}'.format(windll.kernel32.GetLastError())
                                                      notepad.messageBox('Could not register hook:\n{}\n'.format(_err) +
        'Shortcuts won\'t work',
        'Register Hook Failure', 0)
                                              else:
                                                  console.write('no toolbar_handle found')
                                          def unregister(self):
                                              if OLD_WND_PROC:
                                                  self.oldWndProc = OLD_WND_PROC
                                                  dummy = windll.user32.SetWindowLongA(self.toolbar_handle, GWL_WNDPROC, self.oldWndProc)
                                                  if not dummy:
                                                      notepad.messageBox('Could not unregister hook:\n{}\n'.format(_err) +
        'It is recommended to save data and restart npp to prevent data loss',
        'Unregister Hook Failure', 0)
                                              else:
                                                  console.write('ERROR no saved window proc found')
                                          def sciWndProc(self, hWnd, msg, wParam, lParam):
                                              if msg == 0x0201: # WM_LBUTTONDOWN
                                                  global LEFT_MOUSE_CLICK_MOD
                                                  if wParam == 5: # 0x0001 LButton + 0x0004 Shift
                                                      console.write('left mouse click while holding shift\n')
                                                      LEFT_MOUSE_CLICK_MOD = True
                                                  else:
                                                      console.write('left mouse click\n')
                                              return windll.user32.CallWindowProcA (self.oldWndProc, hWnd, msg, wParam, lParam)
                                      _hook = Hook()
                                      if not CAPTURE_MOUSE_CLICK:
                                          _hook.register()
                                          CAPTURE_MOUSE_CLICK = True
                                          console.write('registered')
                                      else:
                                          _hook.unregister()
                                          CAPTURE_MOUSE_CLICK = False
                                          console.write('unregistered')
                                      in another script something like
                                      import datetime
                                      print datetime.datetime.now()
                                      print 'LEFT_MOUSE_CLICK_MOD:{}'.format(LEFT_MOUSE_CLICK_MOD)
                                      The first script gets the handle of the toolbar and hooks it message queue.
                                      Once you click a button the global variable is set and the second script gets executed.
                                      • YaronY Offline
                                        Yaron
                                        Hello Claudia,
                                        Sorry for the late reply. I was not by my PC.
                                        And thank you for the beautiful script. I appreciate your kindness.
                                        Now that you capture both the click and the modifier, there’s no need to use timeout and it works like a charm.
                                        Two follow-up questions with your permission:
                                        1. Customize Toolbar inserts a separator on pressing Shift and left-clicking a toolbar button.
                                          Which module should I import in order to use GetKeyState() and detect Alt?
                                        2. The little programming experience I have is from Firefox.
                                          In that browser adding a right-click functionality to a toolbar button is done as follows:
                                        • Get A specific toolbar button object.
                                        • Add a click listener to that button and assign your own action to right-click.
                                        I suppose this procedure would be more complex in NPP.
                                        Actually you can replace in your script
                                        with
                                        if wParam == 3: # 0x0001 LButton + 0x0002 MK_RBUTTON
                                        and then if you hold the right button down and left-click - you can execute the script in “alternative mode”.
                                        Another simple (and not as elegant) way to run a script in two modes:
                                        In startup (py or lua) add testScriptDefaultMode = True.
                                        Create a script Toggle TestScript Default Mode containing two lines:
                                        global testScriptDefaultMode
                                        testScriptDefaultMode = not testScriptDefaultMode
                                        In TestScript check if testScriptDefaultMode:.
                                        Assign a simple shortcut (e.g. Alt+Spacebar) to Toggle TestScript Default Mode and use it to quickly toggle the modes…
                                        Thanks again.
                                        Have a nice weekend.
                                          @Yaron
                                          The function is also called GetKeyState and is in user32.dll.
                                          You need to provide the virtual key code to get the state, so something like
                                          alt_state = windll.user32.GetKeyState(0x12)
                                          but using wine, I was not able to press alt and do left click with mouse.
                                          Would be interesting to see if this works on Windows.
                                          I think so too. Out of my mind, you would need to find notepad++ window handle,
                                          enumerate child windows to get toolbar, enumerate toolbar child windows to get
                                          the button in question (not sure how to identify), register a function which hooks into
                                          buttons message queue and I don’t know what happens if another program accesses toolbar
                                          to modify (or add/delete) a button?? I’m pretty sure it can be done but I’m not convinced
                                          it should be done.
                                          Another possible solution to run script in alternate mode would be to use a
                                          inputbox (prompt method) ;-) (also not as elegant but most painless version) :-D
                                          • YaronY Offline
                                            Yaron
                                            Hello Claudia,
                                            Great. Thank you.
                                            if alt_state < 0:
                                            Works perfectly.
                                            Out of my mind, you would need to find notepad++ window handle…
                                            Your confirmation that this is indeed rather complex is important.
                                            inputbox
                                            So I have multiple choices now. :)
                                            Being a “mouse-oriented” user, your script detecting if the right button was down when left-clicking would probably fit me best.
                                            Thanks again for your time and clever ideas. I do appreciate it.
                                            S 1 Reply Last reply Reply Quote 1
