    Trouble making a functionList parser for MATLAB
    29 Posts 4 Posters 19.2k Views
    • Per IsaksonP
      Per Isakson
      @MAPJe71 ,
      Your new parser works like a charm. It even handles WeirdUseOfContinuationLine.m. Thank you very much!
      • Per IsaksonP
        Per Isakson
        @MAPJe71
        Sorry, I’m back with more problems. However, the result so far is good enough for me who know the limitations. Other Matlab users may think differently.
        My goal is that the <parser> produces the intended result for syntactically correct Matlab files. Exceptions are acceptable for rare and smelly cases. It’s good if something is shown for syntactically incorrect Matlab files - the more the better.
        The Matlab class syntax, [Class Syntax Guide], includes more than I have “communicated” with the test files in this thread.
        Problem: A Matlab file allows one classdef...end block, which in turn may contain zero or more methods...end blocks. classdef shall be the first keyword in the file. The current <parser> displays the functions of the first methods...end block as belonging to the class, i.e. being methods, and erroneously the functions of subsequent methods...end blocks as functions. This is illustrated by the attached m-file.
        I failed to modify your <parser> to show all function inside the classdef...end block as methods belonging to the class.
        classdef (Sealed) aCompleteClassWithFunction < handle
           properties (Access = private)
              Prop1 = datenum(date)
           end
           properties
              Prop2
           end
           events (ListenAccess = protected)
              StateChanged
           end
           methods
              function obj = aCompleteClassWithFunction(x)
                 obj.Prop2 = x;
              end
           end
           methods (Access = {?MyOtherClass})
              function d = myMethod(obj)
                 d = obj.Prop1 + x;
              end
           end
        end
        function myUtilityFcn
            A = 17;
        end
        • MAPJe71M
          MAPJe71
          @Per-Isakson
          Sigh, it was to good to be true ;-)
          I’ll will look at it tomorrow.
          • Per IsaksonP
            Per Isakson
            @MAPJe71
            I’m obviously not capable to contribute effectively to the code of this <parser>:-(. I lack both regarding knowledge on regular expressions, and understanding of how the <parser>-code produces the function list.
            How important is a good Matlab-<parser> to Notepad++ ? To me Notepad++ is a valuable complement to Matlab’s editor, which is sluggish and doesn’t support regular expressions, not even wildcards. I use Notepad++ daily. Notepad++ is superior when it comes to large files and browsing large code-bases. Google returns 0.18 million results for “notepad++ matlab”.
            I send this post rather to help you decide than insisting on specific things being included in the <parser>. What we achieved so far is good enough for me!
            Is there a mean to make the user aware of limitations in the capability of a specific <parser>. Documented limitations are more acceptable.
            MLC commentExpr
            The colon after ‘MLC’ is that a typo or non-capture?
            Proposal: replace the MLC-code by
            (?xms)
            (?'OMLC' (?>^\h*%\{\h*$))
            (?'CMLC' (?>^\h*%\}\h*$))
            Justification: Again Matlab’s syntax [Add Comments to Programs] is permissive
            • nested multi-line-comments (candidate for documented limitation)
            • single-line-comments inside MLC
            • I often comments out code with both SLC and MLC, because Matlab has a feature, Find in Files, which doesn’t honor MLC (bug). MLC allows me to code-fold the comment-out code.
            This should be matched by MLC
            some code
            %% Section
            %  some other code
            This expression is affected by the block-comment-problem.
            Nested functions
            Matlab have nested functions. My previous <parser> showed functions nested in functions as ordinary functions and functions nested in methods broke the function list (showed only file name). Your current <parser> ignores nested functions altogether, which is better. Candidate for documented limitation.
            function    out = function_scalar_return_nested( val )
                out = 17;
                function nested
                end
            end
            • Per IsaksonP
              Per Isakson
              @MAPJe71
              There is another Matlab feature, which is a strong candidate for documented limitation. In files defining functions and subfunctions, but no nested functions, end is optional in the function ... end block. It’s a legacy from long time ago.
              • MAPJe71M
                MAPJe71
                @Per-Isakson
                Yep, the colon in the MLC commentExpr is a typo.
                FYI: failing to detect multi-line/block comments when the parser has a classRange node appears to be a bug.
                The only way I can think of right now to document limitations of parsers is to add it as comment in functionList.xml. I will do so for this parser.
                Although I haven’t found a solution for multiple ‘methods’ sections within a class definition yet, I think the parser should support it presuming it’s used a lot in OO programming.
                • MAPJe71M
                  MAPJe71
                  @Per-Isakson
                  The latest:
                  |   Note(s):
                  |   1)  One-line class definitions are not supported;
                  |   2)  Nested functions are not supported;
                  |   3)  All functions require an 'end' statement;
                  |   4)  In some situations where a multi-line/block comment contains function definition(s),
                  |       the function(s) is/are still displayed as global function(s).
                  <parser
                  	displayName="MATLAB - MATrix LABoratory"
                  	id         ="matlab_syntax"
                  	commentExpr="(?x)                                    # free-spacing (see `RegEx - Pattern Modifiers`)
                  					(?'MLC'                              # Multi Line Comment
                  						(?m)                             # ...^ and $ match at line breaks
                  						^%\{$                            # ...start-of-comment indicator
                  						(?:                              # ...followed by zero or more characters
                  							[^%]                         # ...not start of start-of-comment indicator
                  						|	%(?![%{}])                   # ...not being an SLC or a start- or end-of-comment indicator
                  						|	(?&amp;MLC)
                  						^%\}$                            # ...end-of-comment indicator
                  				|	(?m-s:%.*$)                          # Single Line Comment (SLC)
                  				|	(?s:\x22(?:[^\x22\x5C]|\x5C.)*\x22)  # String Literal - Double Quoted
                  				|	(?s:\x27(?:[^\x27\x5C]|\x5C.)*\x27)  # String Literal - Single Quoted
                  	<classRange
                  		mainExpr    ="(?x)                               # free-spacing (see `RegEx - Pattern Modifiers`)
                  				(?s-i)                                   # dot matches at line breaks, case-sensitive
                  				\bclassdef\b                             # start-of-class indicator
                  				.*?                                      # whatever, up till...
                  				(?=                                      # ...start-of-class-body indicator
                  					\b
                  					(?:e(?:numeration|vents)|methods|properties)
                  					\b
                  		openSymbole ="(?x)                               # free-spacing (see `RegEx - Pattern Modifiers`)
                  				\b                                       # ensure leading word boundary for start-of-block indicator
                  				(?-i:                                    # case-sensitive start-of-block indicators
                  				|	f(?:or|unction)
                  				|	if
                  				|	methods
                  				|	p(?:arfor|roperties)
                  				|	switch
                  				|	try
                  				|	while
                  				\b
                  		closeSymbole="(?x)                               # free-spacing (see `RegEx - Pattern Modifiers`)
                  				\b                                       # ensure leading word boundary for end-of-block indicator
                  					end                                  # end-of-block indicator
                  				\b                                       # ensure trailing word boundary for end-of-block indicator
                  		<className>
                  			<nameExpr expr="(?x)                         # free-spacing (see `RegEx - Pattern Modifiers`)
                  					\b(?-i:classdef)                     # case-sensitive start-of-class indicator
                  					\h+                                  # required whitespace
                  					(?:\([^)]*?\)\h+)?                   # optional class-attributes
                  					\K                                   # discard text matched so far
                  					[A-Za-z]\w*                          # valid character combination for identifiers i.e. class name
                  		</className>
                  		<function
                  			mainExpr="(?x)                               # free-spacing (see `RegEx - Pattern Modifiers`)
                  					(?ms-i)                              # ^, $ and dot match at line breaks, case-sensitive
                  					(?:	^                                # a function can be found at start-of-line
                  					|	[,;]                             # ...or after a separator
                  					)\h*                                 # ...optionally followed by whitespace
                  					\bfunction                           # ensure word boundary for start-of-function indicator
                  					\s+                                  # required whitespace separator
                  					.*?                                  # whatever, until...
                  					\bend\b                              # ...the first end-of-block indicator
                  			<functionName>
                  				<funcNameExpr expr="(?x)                 # free-spacing (see `RegEx - Pattern Modifiers`)
                  						function\s+                      # start-of-function indicator
                  						(?:\.{3}\s+)?                    # optional continuation-line indicator
                  						(?:                              # optional return value(s)
                  							(?:	\w+                      # ...single variable name
                  							|	\[[\h,\w]*\]             # ...or one or more variable names in brackets
                  							)\h*=\h*                     # ...followed by a separator with optional whitespace
                  						[A-Za-z]\w*                      # valid character combination for identifiers i.e. function name
                  						\b                               # ensure word boundary for name
                  						(?:                              # optional parameter list
                  							\s*                          # ...optional leading whitespace
                  							\(                           # ...start-of-parameter-list indicator
                  							[\h,\w~]*                    # ...with optional parameters
                  							(?:	\)                       # ...until end-of-parameter-list indicator
                  							|	\.{3}                    # ...or continuation-line indicator
                  				<!-- comment out the following node to display the method with its parameters -->
                  <!--				<funcNameExpr expr="(?:(?:\w+|\[[\h,\w]*\])\h*=\h*)?[A-Za-z]\w*" /> -->
                  			</functionName>
                  		</function>
                  	</classRange>
                  	<function
                  				^\h*                                     # optional leading whitespace at start-of-line
                  				function\b                               # start-of-function indicator
                  		<functionName>
                  <!--			<nameExpr expr="(?:(?:\w+|\[[\h,\w]*\])\h*=\h*)?[A-Za-z]\w*" /> -->
                  		</functionName>
                  	</function>
                  </parser>
                  • Per IsaksonP
                    Per Isakson
                    @MAPJe71
                    Thank you for your latest parser.
                    I’ve tested your latest parser and the parser I attach below with the files in a couple of real Matlab programs.
                    Your latest parser handles “multiple ‘methods’ sections” well in most cases. I failed to spot what characterizes the few cases, which show methods as functions.
                    One lesson I learned is that I must be more careful so that the test cases covers all relevant parts of the syntax of the target language. I previously missed that
                    • the keyword, end, is used as index, e.g A(end) is the last element of the vector A.
                    • apostrophe, ', is shorthand for the function, transpose, e.g. A' is equal to transpose(A)
                    My latest parser works as expected, i.e. I haven’t seen it fail yet. However, it puts higher requirements on the target Matlab code; it will fail with more files.
                    I have included two parsers in functionList.xml, one for the UDL matlab2. I switch between the two
                    by the menu entries, Language|matlab2 and Language|M|Matlab, respectively. The obviously overtakes the extension, .m2.
                    I plan to upload my parsers to Matlab File Exchange to see it I get any interest.
                    <!-- P09, KISS, full function signature
                    Limitations and requirements
                    1.1 The keyword, 'classdef', shall start a new line; no indentions
                    1.2 The keyword, 'end', which match 'classdef', shall start a new line
                    1.3 No keyword, 'end', shall start a new line inside the classdef block
                    2.1 The keyword, 'function', optionally indented, shall start a new line
                    3.1 The line of the last keyword, 'end', shall be ended by a new line character
                    4.1 Nested functions are displayed as methods and sub-functions, respectively.
                    5.1 Block comments must not be nested; no block comment inside a block comment
                    6.1 Function blocks shall be ended by the keyword, 'end'
                    7.1 The file shall contain at least one method or function
                                <parser
                                    id         ="matlab2_syntax"
                                    commentExpr=   "(?x)                        # free-spacing
                                                    (?m)                        # ^ and $ match at line breaks
                                                    (?-s)                       # dot does NOT match new line
                                                    (?:                         # Multi Line Comment, (MLC)
                                                        (?:^\h*\x25\x7B\h*$)    # '%{' with optional space
                                                        (?s:.*?)                # lazy: any character up till
                                                        (?:^\h*\x25\x7D\h*$)    # '%}' with optional space
                                                    |                           # or
                                                    (?:                         # Single Line Comment (SLC)
                                                            \x25                # '%'
                                                            |                   # or
                                                            \x2D{3}             # '...'
                                                        ).*?$                   # and up till end of line
                                                    |                           # or
                                                    (?:\x27(?:.*?)*\x27)        # String Literal - Single Quoted - on one line
                                     <classRange
                                        mainExpr = "(?x)                        # free-spacing
                                                    (?s)                        # dot matches new line
                                                    (?-i)                       # case-sensitive
                                                    ^classdef\h+                # start-of-class indicator at start-of-line
                                                    (?:.*?)                     # whatever, until...
                                                    ^end                        # end-of-class indicator at start-of-line
                                        <className>
                                                    \bclassdef                  # case-sensitive start-of-class indicator
                                                    [A-Za-z]\w*                 # valid Matlab identifiers; class name
                                        </className>
                                        <function
                                                    ^\h+                        # required intendation
                                                    function                    # start-of-function indicator
                                                    \h+                         # required whitespace separator
                                                    .*?$                        # whatever, up till the end of line
                                            <functionName>
                                                        function\h+             # start-of-function indicator
        |               # or
        \[[\h,\w]*\]    # ...one or more names in square brackets
                                                            \h*=\h*             # ...a separator with optional whitespace
                                                        [A-Za-z]\w*             # valid Matlab identifiers; method name
                                                            \h*                 # ...optional leading whitespace
        \)              # ...up till end-of-parameter-list indicator
        |               # or
        \.{3}           # ...continuation-line indicator
                                            </functionName>
                                        </function>
                                    </classRange>
                                    <function
                                                    ^\h*                        # optional intendation
                                                    .*?$                        # whatever, until end of line
                                        <functionName>
                                                    (?:\.{3}.*$)?               # optional continuation-line indicator
                                                            |                   # or
                                                            \[[\h,\w]*\]        # ...one or more variable names in brackets
                                                    [A-Za-z]\w*                 # valid Matlab identifiers; function name
                                                            |                   # or
                                        </functionName>
                                    </function>
                                </parser>
                    Alternate <functionName> block to show method and function name (without input and output arguments)
                                        <functionName>
                                                            |                   # or
                                        </functionName>
                    • MAPJe71M
                      MAPJe71
                      @Per-Isakson
                      *indentation ;-)
                      Glad you found a parser that meets your needs!
                      I propose to wait for feedback from other Matlab users (I’m not one of them) before including it in an official N++ release.
                      • Per IsaksonP
                        Per Isakson
                        @MAPJe71
                        I’ve finally uploaded some <parser>-elements to the Matlab File Exchange.
