    v7.3.3 - Fix CIA Hacking Notepad++ issue
    53 Posts 26 Posters 114.2k Views
    • donhoD
      donho
      “Vault 7: CIA Hacking Tools Revealed” has been published by Wikileaks recentely, and Notepad++ is on the list.
      The issue of a hijacked DLL concerns scilexer.dll (needed by Notepad++) on a compromised PC, which is replaced by a modified scilexer.dll built by the CIA. When Notepad++ is launched, the modified scilexer.dll is loaded instead of the original one.
      It doesn’t mean that CIA is interested in your coding skill or in your sex message content, but rather it prevents raising any red flags while the DLL does data collection in the background.
      It’s not a vulnerability/security issue in Notepad++, but for remedying this issue, from this release (v7.3.3) forward, notepad++.exe checks the certificate validation in scilexer.dll before loading it. If the certificate is missing or invalid, then it just won’t be loaded, and Notepad++ will fail to launch.
      Checking the certificate of DLL makes it harder to hack. Note that once users’ PCs are compromised, the hackers can do anything on the PCs. This solution only prevents from Notepad++ loading a CIA homemade DLL. It doesn’t prevent your original notepad++.exe from being replaced by modified notepad++.exe while the CIA is controlling your PC.
      Just like knowing the lock is useless for people who are willing to go into my house, I still shut the door and lock it every morning when I leave home.
      We are in a f**king corrupted world, unfortunately.
      https://notepad-plus-plus.org/news/notepad-7.3.3-fix-cia-hacking-issue.html
      • QuppaQ
        Quppa
        As you note, if the hackers have the ability to drop a DLL into the Notepad++ application directory, they can probably do just about anything they want. They’re already on the other side of the airtight hatchway, as Raymond Chen would put it.
        • cipher-1024C
          cipher-1024
          Don,
          Thank you for adding the “Improve multi-line tab: maintaining the selected tab position.” feature. That will make life easier for me. Sadly, that feature seems to have disabled the tab drag-and-drop ability when in mulit-line mode. Maintaining the rows of tabs is more important to me, but if both functions could work together, that would be great.
          Thanks also for doing the scilexer.dll fix. Regardless of how compromised the system is, I’m glad you have the pride to do everything you can to make sure it doesn’t happen in your house.
          Respect
          AngryGamerA 1 Reply Last reply Reply Quote 3
          • yarumoSanY
            yarumoSan
            Wear a safety reflector and use anti-virus is all that most people need to know. Patching just 1 car has little effect on overall security.
            GesusJuiceG 1 Reply Last reply Reply Quote 0
            • GlacialManYTG
              GlacialManYT
              Hi and thanks for all. Maybe, my problem but I see the error of SciLexer.dll starting Notepad++ 32-bit on Win 10 Pro 64-bit Anniversary Edition. Has anyone noticed the same?
                Claudia Frank @GlacialManYT
                @GlacialManYT
                What exactly is the error message?
                and do you have a SciLexer.dll in the directory where notepad++.exe has been installed?
                • GlacialManYTG
                  GlacialManYT
                  C:\Program Files (x86)\Notepad++\SciLexer.dll
                  CRC32: 7ffc0f72
                  Certificate checking
                  Check certificate of C:\Program Files (x86)\Notepad++\SciLexer.dll : Impossible to find the specified object
                  OK
                  Exception on WM_CREATE
                  ScintillaEditView::init : SCINTILLA ERROR - can not load the dynamic library
                  OK
                    @GlacialManYT
                    and from where did you download notepad++?
                    • GlacialManYTG
                      GlacialManYT
                      https://notepad-plus-plus.org/repository/7.x/7.3.3/npp.7.3.3.Installer.exe
                      CRC32: 8e15096a
                      I also tried to disable AV and to install as admin
                      Sorry but I’m a new user, I haven’t earned 2 reputation and I can only post once every 1200 seconds…
                      Claudia FrankC 1 Reply Last reply Reply Quote 2
                        @GlacialManYT
                        OK, I installed VirtualBox and loaded my aged Winodws 10 64bit VM,
                        Downloaded npp7.3.3 (32bit) and installed it.
                        Started npp - no problem. (The only problem is that it takes ages because of my old pc isn’t really capable of doing it.)
                        So what is specific to your setup? Any ideas?
                        • donhoD
                          donho
                          It seems your SciLexer.dll in C:\Program Files (x86)\Notepad++ is not signed.
                          Could you send me your SciLexer.dll to don.h@free.fr please?
                          • GlacialManYTG
                            GlacialManYT
                            E-Mail message sent.
                            • donhoD
                              donho
                              @GlacialManYT Thank you.
                              I have checked. The file (scilexer.dll) is correct.
                              Could you
                              1. make sure your OS is updated and restart your PC.
                              2. download minimalist package both 32/64 bith version from notepad-plus-plus.org, create npp32 & npp32 under *c:\temp*, unzip both into c:\temp\npp32 & c:\temp\npp64 respectively, then give both a try?
                                Hello, Don,
                                How are you ? Not too traumatized by the recent CIA Hacking issue. Thank you, for caring about our global security :-))
                                Don, from the discussion, between Jean Heck, Mkupper and Claudia :
                                https://notepad-plus-plus.org/community/topic/13374/double-click-links-no-longer-work/1
                                I realized some tests. And, indeed, there is a bug, with clickable links, in the last versions of Notepad++
                                To reproduce the bug :
                                • Create a simple text file, named test.txt under the root C:\ of your machine
                                • Start Notepad++
                                • Open, first, any file, for instance, the change.log file
                                • Now, in a new tab, type the single line, below :
                                  file://C:/test.txt
                                • Save this text file as Test_Lang.txt
                                • Change the language of the Test_Lang.txt file to any language
                                • Select the change.log file and, immediately, go back to the Test_Lang.txt file
                                ( Note : this “switch” action allows to active the link, again ! )
                                • Finally, double-click on the file://C:/test.txt link
                                => I noticed that the double-click does NOT work, for the four languages ASP HTML JSP PHP, if the N++'s version is superior or equal to v7.3 !
                                For all other languages, included Normal Text, the double-click DOES work and opens, as expected, the test.txt file, in Microsoft Notepad :-)
                                P.S :
                                • Of course, I suppose that the option Enable, in Settings… > Preferences… > MISC. > Clickable Link Settings is checked !
                                • Perhaps, the reason(s) why double-click doesn’t work for the four languages ASP, HTML, JSP and PHP is(are) not the same for each of them :-((
                                dailD 1 Reply Last reply Reply Quote 1
                                • qma sterQ
                                  qma ster
                                  I believe that enforcing the signature checking for just scilexer.dll is not enough:
                                  if I were a hacker, after this patching if I still want to hack a Notepad++
                                  I would just move to the next DLL !
                                  Question: why not enforce the signature checking for all the Notepad++ DLLs?
                                  • GlacialManYTG
                                    GlacialManYT
                                    Hi Don, thanks for your help, I will make the test that you have suggested, as soon as possible. I take this opportunity to point out a small anomaly. When in Notepad++ several files are opened (txt, bat, cmd), if I modify or I delete any of these files, and Notepad++ is opened in background, when I switch to Notepad++ an useful window asks to me if I want to update the situation. The problem comes when I modify or I delete an opened file and, after, without switching to Notepad++, I open a file, I expect that its tab is selected, in the foreground, but, after having responded to the question of the said window, file is not pointed and I must search for it in the open tabs of Notepad++ (that generally are many). After the answer, according to me, should be selected the tab of the last opened file (or in phase of opening). Obviously, if I have modified or deleted some files, the questions are one for each file and, at the end of the answers, as said, should be selected the tab of the last opened file (or in phase of opening). That’s all, not so important but useful.
                                    • dailD
                                      dail @guy038
                                      @guy038 @donho
                                      I’ve opened https://github.com/notepad-plus-plus/notepad-plus-plus/pull/3019 which solves the issue with clicking links in certain file types.
                                      • GlacialManYTG
                                        GlacialManYT
                                        @donho : I have deeply uninstalled notepad++ 32-bit v7.3.3 and, after, I have cleaned the registry but the error persists. I have the same problem with all 32-bit versions ( I made a test also with this http://portableapps.com/apps/development/notepadpp_portable ). Instead, all 64-bit versions are working regularly. So, I’m using the 64-bit version also if, for now, I would prefer the 32-bit version, that supports all plug-ins. I can make a test on others Windows 10 Pro 64-bit Anniversary Edition. See you soon.
                                          @GlacialManYT
                                          Can you run ProcMon to see what’s going on?
                                          Once downloaded, start it, create a filter for SciLexer.dll (Path ends with)
                                          make sure that (toolbar buttons) file system activity and process and thread activity
                                          have been pressed and start npp.
                                          What’s the result?
                                          • GlacialManYTG
                                            GlacialManYT
                                            Thanks for your help Claudia, there was a system problem that I solved. Now all is ok.
                                            StarBeat HDS 1 Reply Last reply Reply Quote 0
