    Pythonscript search different than N++ search when using \< and leading uppercase
    25 Posts 5 Posters 17.2k Views 4 Watching
    • Claudia FrankC Offline
      Claudia Frank
      Hi Guy,
      thx for your effort on this but I have to disagree with your disagree ;-D
      From regex execution point of view there are two ways to change
      the case behavior. Either by providing a flag or using the in-line modifiers.
      When providing the flag everything is ok (at least for the moment) - so
      I have to assume that the regex engine works correctly in this case.
      When providing the in-line modifier and the flags then it isn’t ok always.
      This does mean there is a bug and it must be related to how in-line modifiers
      are handled against flags. And that makes me think that the bug is when doing
      this overwrite - which means we can’t rely on it. Maybe other in-line modifiers
      together with some special regex constructs behave wrong as well.
      • guy038G Offline
        Hello, Claudia and All,
        Hum…,finally, Claudia, I think that you’re right :-) Indeed, if we built the general table, below, which recapitulates the main cases, it’s obvious that :
        • Results are OK, when the “Match case” flag, is ONLY used, WITHOUT any in-line modifier ( Lines 1 and 4 )
        • Results seem OK, ( UP TO NOW ), when the “Match case” flag is used, with a starting (?-i) in-line modifier ( Lines 3 et 6 )
        • Results seem OK, ( UP TO NOW ), when the “Match case” flag is OFF, with a starting (?i) in-line modifier ( Line 2 )
        • Results are NOT OK, when the “Match case” flag is ON, with a starting (?i) in-line modifier and a regex which begins with the \< assertion ( Line 5 )
        Luckily, this LAST case ( Line 5 ) is rather rare and does not occur if we use the \b syntax, instead of \< :-))
        |  Row  |   "Match case" flag   |  In-line modifier  |  Results  |     Remarks      |
        |   1   |          OFF          |         NO         |  Correct  |  Implicit (?i)   |
        |   2   |          OFF          |        (?i)        |  Correct  |                  |
        |   3   |          OFF          |        (?-i)       |  Correct  |                  |
        |   4   |          ON           |         NO         |  Correct  |  Implicit (?-i)  |
        |   5   |          ON           |        (?i)        |  PROBLEM  |  IF use of \<    |
        |   6   |          ON           |        (?-i)       |  Correct  |                  |
          First of all, it is great to see such rousing discussion about the issue I discovered! :-) Thanks to all for that.
          There are lots of things to think about coming out of this discussion, but the most obvious and immediate one is a question for Mr Guy: You keep suggesting to use \b instead of \< , but they are not always equivalent, correct? They may be equivalent for certain examples, but in the most general case I believe they are different. If they weren’t different, there would be no reason for both to exist in the N++/Boost engine…
          I mean, even I discussed using \b instead in my very first posting in this thread, but that was just as a test, not necessarily a blanket substitution. I guess I don’t want others reading this thread to takeaway that \b and \< are the exact same thing.
          Comments? Thoughts?
          • MAPJe71M Offline
            MAPJe71
            See reference on Word Boundaries for
            • description on differences between \b, \< and \>;
            • which “engine” supports what.
            • guy038G Offline
              Hi Alan and MapJe71,
              Thanks, MapJe71, for the link about Word Boundaries, from the definitive site about regular expressions ! Of course, Alan, I know the differences between the three assertions : \b , \< and \>. I just preferred not to speak about it, first, in order to keep concentrated on your problem !
              To be short, the \b assertion acts, either, as a \< assertion OR as a \> assertion. This explains that the regex \<WORD\> can be simply replaced by the regex \bWORD\b.
              BTW, in the Words Boundaries table, I noticed the POSIX word boundaries ( [[:<:]] and [[:>:]] ) which have, exactly, the same meaning as the GNU word boundaries \< and >\ ). These syntaxes are functional, with the N++ Boost regex engine ! Unfortunately, Alan, the problem that you noticed does occur with the POSIX word boundaries, too :-((.
              On top of that, from the LAST row of the “Word Boundaries” table, named Word Boundaries behaviour, it is said that “word boundaries” are not correctly handled, in most regex engines :
              Word boundaries always match at the start of the match attempt if that position is followed by a word character, regardless of the character that precedes the start of the match attempt. (Thus, word boundaries are not handled correctly for the second and following match attempts in the same string.)
              And it shows an example :
              \b. matches all of the letters but not the space when iterating over all matches, in the string “abc def”
              So, I did some tests ( again !! )
              • I copied this single sentence, below, part of the license.txt file, in a new tab
              By contrast, the GNU General Public License is intended to guarantee your freedom...
              • In the Find dialog, I left the Match case and the . matches newline options UNCHECKED
              • I selected, of course, the Regular expression search mode
              • I tested the different regexes, below, against the example text
              REMARK : In the table, below, each dash character, under the sentence, indicates a match of the corresponding regex(es) !
              |     REGEXES     |                EXAMPLE text    -     MATCHES noted by a DASH character               |   RESULTS   |
              |                 | By contrast, the GNU General Public License is intended to guarantee your freedom... | INCORRECT ! |
              |  (^|(?<!\w)).   | ------------------------------------------------------------------------------------ |             |
              |  \b.            |        |             |
              |  \b\w           | -- --------  --- --- ------- ------ ------- -- -------- -- --------- ---- -------    |             |
              |  \<\w           |        |             |
              |  [[:<:]]\w      |        |             |
              |  (^|(?<!\w))\w  |        |             |
              |                 | By contrast, the GNU General Public License is intended to guarantee your freedom... |  INCORRECT  |
              |  (^|(?<=\W)).   | -  -        -    -   -       -      -       -  -        -  -         -    -       -  |             |
              |                 |        | (At last !) |
              |                 | By contrast, the GNU General Public License is intended to guarantee your freedom... |             |
              |  (^|(?<=\W))\w  | -  -         -   -   -       -      -       -  -        -  -         -    -          |   CORRECT   |
              |  .\b            |  --       - -  --  --      --     --      -- --       -- --        --   --      -    |             |
              |  .((?=\W)|$)    | By contrast, the GNU General Public License is intended to guarantee your freedom... | INCORRECT ! |
              |  .((?!\w)|$)    |  -        --   -   -       -      -       -  -        -  -         -    -       ---- |             |
              |  \w\b           | By contrast, the GNU General Public License is intended to guarantee your freedom... |   CORRECT   |
              |  \w\>           |  -        -    -   -       -      -       -  -        -  -         -    -       -    |             |
              |  \w[[:>:]]      |        |             |
              |  \w((?=\W)|$)   |        |             |
              |  \w((?!\w)|$)   |        |             |
              From that table, it obvious that the handle of the assertions, by the N++ Boost engine, seems quite weird !!!
              To be coherent, only two regexes, with similar syntax, should be used :
              • The regex (^|(?<=\W))\w, which matches the FIRST character of a word
              • The regex \w((?=\W)|$), which matches the LAST character of a word
              => The regex (^|(?<=\W))\w|\w((?=\W)|$) matches the first AND the last characters of a word
