Plugin built with VS 2013 Express vs. Plugin built with VS 2013 Community
Yaron, could you post your compare.ini?
Claudia -
This is were I currently investigate, to be more precise I assume the issue in addBlankSection.
Claudia -
You’re amazing.
On one hand I think that it’s too much, but on the other hand I don’t want you to stop. :)
I was about to start investigating it myself; I was overwhelmed by the scale of the unfamiliar code.
Thank you very much!
It might be that this was a hasty reaction as it could be that the function already got the wrong value.
What I can say so far is that the inserttext from addBlankSection::SendMessage(window, SCI_INSERTTEXT, posAdd, (LPARAM)buff.data());only gets one '\r\n”
{'text': '\r\n', 'modificationType': 0x11, 'linesAdded': 1, 'length': 2, 'position': 3, 'line': 0 }whereas my dll gets three
{'text': '\r\n\r\n\r\n', 'modificationType': 0x11, 'linesAdded': 3, 'length': 6, 'position': 3, 'line': 0 }Test was done with two files, one having
1 5whereas the other has
1 2 3 4 5It is most likely that I need your help to find out what the problem is, meaning
you need to do some debugging as well. But not for today, I need to have a rest.
Maybe we can go on tomorrow?Cheers
Claudia -
Good morning Claudia,
I hope you’re reading these lines after having a good and refreshing rest.
I find it difficult to enlarge the variety of my thanks expressions.
So, many thanks again. :)I’ve never used the Debugger.
Bear with me.Have a great day.
Hello Yaron,
The problem is generated by a compiler bug. It tries to optimize a little bit too much. ;-)
Either disable optimization, by right clicking on compare in project explorer,
properties -> C/C++ -> all options -> Optimization and change its valueor the preferred way
update your visual studio 2013 to latest version. ;-)
Claudia -
Hello Claudia,
You never cease to amaze me.
I take my hat off. Oracle Claudia!Thank you so much. I’m truly grateful.
Could you please enlighten me and explain briefly how you got it?
I hope it’s not a trade secret. :)Best regards.
Hello Yaron,
no, it isn’t a trade secret ;-) - but it wasn’t really a clever job, it was just an eliminating process and LUCK.
I only tell you the steps which lead to the finding not the many wasted miserable steps I’ve done before. ;-)
After I didn’t find any obvious issues which could explain reported behavior I thought about the differences of your
and mine environment. After that I setup an windows 7 32 bit with visual studio 2013. Downloaded source and compiled it.
Tested it and it worked. Even more confused as I expected it to fail. Thought about it again and started comparing yours and mine.
Same W7, same VS2013, same source -> different results.
Same W7 (?) -> didn’t install all updates -> didn’t use Hebrew = keep in mind
VS2013 -> same
source-> same, you did even test it with different npp version as I read.
So it must be W7 -> why??? Did a search on the internet about reporting problem with VS2013 and non-english language.
Results, but nothing pointing to such an issue.
Then I did a search about problems with visual studio and having different language. And while scanning the result
I saw one who had an issue installing an update - that’s where I started thinking about different version.
I had VS2013 update 4 already so I gave it a chance and -> compiled the source and tested it -> problem was the same.You see, no rocket science.
Claudia -
Hello Claudia,
Thank you for the explanation. You know, men can get curious too. :)
And now I just can’t help it.
After explaining the process of reasoning leading to her famous deductions, Shirley Holmes’ insights seemed to lose some of their former glamour.
But then on a second thought the shine became even brighter.Well, I assumed you had performed some searches and tests.
Now that I know the scale of those actions, my gratitude grows and deepens.And finally, rocket science would be no “rocket science” for you. :)
Best regards.
