    Who is responsible for viewing and claiming users suggestions ?
    43 Posts 4 Posters 60.5k Views
    • John SparkJ
      John Spark
      Oh yes, what a fail of me.
      I changed it to claudia commands in .txt file.
      Now run NP++ and there is again that situation:
      • console is not loaded - which is ok
      • I press F6 - nothing prompted, just eyeblink time flash something
      • repeated press, same thing
        Claudia Frank @John Spark
        @John-Spark
        you started npp and pressed F6? Not SHIFT F6?
        • John SparkJ
          John Spark
          correct
          Claudia FrankC 2 Replies Last reply Reply Quote 0
            @John-Spark
            but after start of npp you should press SHIFT+F6
              @John-Spark
              I double checked the shortcuts.xml
              After start of npp you need to press CTRL+F6
              • John SparkJ
                John Spark
                Oh my Lord. There is difference between F6 and Ctrl+F6 ?
                I thought, it’s just prompting screen.
                It works now. On start Imust ctrl+f6.
                This is, how you meant it from beginning + is this best way closest to one key press as I need ? Anything better can’t be made right now ?
                MANY THANKS FOR YOUR PATIENCE AND TIME AND EFFORT. I OWE YOU !
                  @John-Spark
                  yes, that’s the closest we can get, First time it must run the execute dialog.
                  Glad to see that we’ve done it.
                  What’s next?
                  If there is one, please open a new thread this one is getting to big.
                  • John SparkJ
                    John Spark
                    In this last post I would like to just summarize what was this all about.
                    Two suggestions:
                    #1, Ability to delete Auto-Inserted (Auto-Completion Preferences menu) half of dual symbol (parenthesis, brackets, curly braces, quotas…) by pressing Backspace. It means to remove whole double symbol by deleting it’s first half wrote manually in origin.
                    #2, Ability to delete Tabbed whitespaces (by pressing Backspace), transformed to regular spaces due to Tab Settings in Preferences; in sense of one Backspace = one deleted tabbed whitespace. It means not x-times pressed Backspace to delete one tabbed whitespace.
                    I know I may look like as incompetent total stupider after this whole topic, but my suggestions aren’t stupid. Thanks devs for considerating it.
                    Bye all
                    • John SparkJ
                      John Spark
                      and forgot:
                      #3, Ability to reset key bindings to default from GUI. For beginners who never used such poweful notepad and are trying to find their own efficient work habits.
                      • John SparkJ
                        John Spark
                        #4, Ability to exclude numbers from Auto-Completion.
                        And ability to exclude specific strings from Auto-Completion per file or default for anything opened !
