    Please help me
    4 Posts 2 Posters 470 Views
    • rafiq khanR
      rafiq khan
      I have installed nppftp plugin I configured the plugin and try to connect it It gives me the following error message and exits .
      WIN32 EXCEPTION
      An exception occurred notpad++ cannot recovered and must be shutdown .
      the exception details are as below
      code 0xc000000005
      type Access violation
      exception address ox6465Ec26
      I tried many versions but nothing work .I reinstall the os but same results .I need this plugin to work in my system how to solve the problem I shell be very thankful to you
      Thank you
        Maybe you wanna explain what exactly you did on which OS, with which npp version etc… See here.
        • rafiq khanR
          rafiq khan
          well thanks for reading my post
          i am using windows and want to edit my files on ftp with nppftp.It gives the exception win32 message whenever i try to connect it to my ftp account .
          WIN32 EXCEPTION
          code 0xc000000005
            Ekopalypse @rafiq khan
            @rafiq-khan
            Please post the debug-info from ? menu, the last menu item.
            How did you install nppftp?
