    Control symbols now inserted on macro
    27 Posts 6 Posters 4.3k Views
      Ekopalypse @PeterJones
      agreed - very strange. I’m wondering if XP and Wine share the same code
      for the needed functionality is this case.
      Would make some sense. Maybe some older unicode library or different than W7 and W10.
      I thought about it for some time now, but I don’t see
      how to start on this to track down the bug.
      andrecool-68A 1 Reply Last reply Reply Quote 2
      • andrecool-68A
        andrecool-68 @Ekopalypse
        @Ekopalypse There has been a problem with the definition of encodings for a very long time, sometimes it is solved but partially))
        And then a new surprise appears with encodings))
          Ekopalypse @andrecool-68
          @andrecool-68 said in Control symbols now inserted on macro:
          :-) I agree but it has reached a new level I would say. :-(
          I can live with limitation if I understand why their are,
          but fishing in the dark for understanding drives me mad.
          • andrecool-68A
            @Ekopalypse This is no longer fishing … it’s sex with a concrete wall))
              @andrecool-68
              :-D ouch
                I finally was able to get this problem to replicate under debugger control (what I was missing before was that my file was coming up with ANSI encoding preselected – and I didn’t notice that; now when the debugger starts up I go in to the N++ Encoding menu and change it to UTF-8).
                Here’s the problem:
                void recordedMacroStep::PlayBack(Window* pNotepad, ScintillaEditView *pEditView)
                	if (_macroType == mtMenuCommand)
                		::SendMessage(pNotepad->getHSelf(), WM_COMMAND, _wParameter, 0);
                	else
                		// Ensure it's macroable message before send it
                		if (!isMacroable())
                			return;
                		if (_macroType == mtUseSParameter)
                			char ansiBuffer[3];
                			::WideCharToMultiByte(static_cast<UINT>(pEditView->execute(SCI_GETCODEPAGE)), 0, _sParameter.c_str(), -1, ansiBuffer, 3, NULL, NULL);
                The ::WideCharToMultiByte call returns 0 – indicating failure – and then a call to GetLastError returns 122 which is ERROR_INSUFFICIENT_BUFFER.
                Indeed, the size of ansiBuffer, i.e., 3, is one too small for this case.
                Changing it to 4 cures the problem for the UTF-8 files:
                char ansiBuffer[4];
                ::WideCharToMultiByte(static_cast<UINT>(pEditView->execute(SCI_GETCODEPAGE)), 0, _sParameter.c_str(), -1, ansiBuffer, 4, NULL, NULL);
                  @Alan-Kilborn said in Control symbols now inserted on macro:
                  … ansiBuffer[4];
                  That makes some sense. At first I was wondering what change prompted that to start failing, and the GitHub blame shows those two lines haven’t been changed in 3-4 years. But really, if Scintilla changed the way it’s doing things, maybe the _sParameter.c_str() now has a 4byte char rather than a 3byte char, or something.
                  Alternately, MS Docs: WideCharToMultiByte shows that sending cbMultiByte (the 3 or 4 in the last arg before the NULLs) as a 0 will have it return the width needed, so wouldn’t it be more future proof to use:
                  int ansiBufferLength = ::WideCharToMultiByte(static_cast<UINT>(pEditView->execute(SCI_GETCODEPAGE)), 0, _sParameter.c_str(), -1, ansiBuffer, 0, NULL, NULL);  // grab needed ansiBuffer length
                  ::WideCharToMultiByte(static_cast<UINT>(pEditView->execute(SCI_GETCODEPAGE)), 0, _sParameter.c_str(), -1, ansiBuffer, ansiBufferLength, NULL, NULL);
                  (though you’d need to either re-dim ansiBuffer, or make sure it’s always got enough room)
