    Drag and Drop not working in portable 7.6.3
    15 Posts 5 Posters 4.3k Views
      Alan Kilborn @andrecool-68
      @andrecool-68
      I take it that you are saying that drag and drop works fine for you from Total Commander to N++ 7.6.3?
      andrecool-68A 1 Reply Last reply Reply Quote 1
      • andrecool-68A
        andrecool-68 @Alan Kilborn
        Yes this is the latest version of Notepad++ and these builds are portable
        • andrecool-68A
          andrecool-68 @Pere Drinovac
          @Pere-Drinovac
          Or do you need to make Notepad++ the default editor for Total Commander?
          • Meta ChuhM
            Meta Chuh moderator @Pere Drinovac
            @Pere-Drinovac
            under normal circumstances drag and drop from total commander will work correctly, as seen at the screen video of @andrecool-68
            i can however reproduce what you see, if either total commander is running elevated as administrator, while notepad++ is running as a default user, as well as if it is the other way round.
            if you need one of them to run elevated as administrator, to e.g. be able to access protected files, you will have to disable the windows user access control (uac) as uac is the cause that blocks passing data from user level applications to elevated applications and vice versa.
            to disable uac in windows 10:
            • hit the windows icon and type uac in the search field as seen at the screenshot below:
            alt
            • then open up Change User Account Control settings and slide the slider down to the bottom as seen at the screenshot:
            alt
            • then hit ok and reboot your machine.
              after reboot, you will now be able to drag and drop files from total commander to notepad++ under (usually) all circumstances.
            note: keep in mind, that uac is activated for security reasons, to make sure no application can write or change some vital file locations, without your consent, but you will be on the safe side as long as you take care of what you are doing.
            i hope this is of help to you.
            • Pere DrinovacP
              Pere Drinovac
              Both, Total Commander and N++, are portable and running with user privileges. Deactivating UAC doesn’t change anything.
              I have figured out, that I used TC as 32Bit version and N++ as 64Bit version. Using N++ as 32Bit version solves the problem.
              Meta ChuhM chetanDNC 2 Replies Last reply Reply Quote 2
              • andrecool-68A
                andrecool-68
                I have everything works fine on all portable versions, no matter x32 or x64 (in any combination!)
                • andrecool-68A
                  andrecool-68
                  @Pere-Drinovac
                  I have now changed the UAC settings. And these changes to UAC settings do not affect this operation at all! Everything works fine.
                  • Meta ChuhM
                    @Pere-Drinovac
                    thanks for sharing your solution.
                    i’m glad you got drag and drop working by using the 32 bit versions for both, without needing to disable uac.
                    @andrecool-68
                    yes, it might be that our systems differ somehow from the original poster’s system.
                    i also get the same results as you did: i can drag from 32 bit total commander to 64 bit notepad++ without any problems.
                    and if uac is enabled on my test-machine, i can drag and drop from an elevated total commander to a user level notepad++,
                    but i can not drag and drop from a user level total commander to an elevated notepad++.
                    i guess the most important thing is, that the o.p. has managed to get drag and drop working for him, regardless how ;-)
                    • Pere DrinovacP
                      Pere Drinovac
                      I would like to thank all of you for the help.
                      • chetanDNC
                        chetanDN @Pere Drinovac
                        @Pere-Drinovac said in Drag and Drop not working in portable 7.6.3:
                        Solved for me too. I was using ClearCase (Windows 32 bit application). Drag and Drop from ClearCase 32 to notepad++ 32 bit works fine. On the other hand drag and drop from any win 32 application to notepad++ 64 bit is not working.
